KTL KTL is offline
Schleprock
KTL's Avatar
Understood the Mobil Vtwin is intended for air/oil cooled use. But the one thought I had, is there any downside to the dual usage it provides- it also serves the motorcycle transmission and wet clutch?
Kevin L
'86 Carrera "Larry"
Old 07-25-2013, 07:54 AM
BURN-BROS's Avatar
Originally Posted by johnman001 View Post
Please sir, could you expound upon this please?
You have used "all types" of oils for break in? What do you use once broken in?
(I have also done this but have been shunned as all the "technical data" on oils was typed up on the internet.)
I may be old school, but I truly believe in clean oil with a clean filter.
All types meaning off the shelf any brand Detergent.
I would run the engine, set up a baseline tune then drain the oil. About 2 hrs of run time in total. Then Delo or Brad Penn...I'll discuss Henry's Brad Penn finding with him as I have not heard about it.
The only critical area for oil I have seen is the Cams/rockers. The majority of issues been reground rocker arms that are not parallel.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-25-2013, 12:03 PM
johnman001's Avatar
Thank you!
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 07-25-2013, 08:04 PM
Banned
This question usually gets the same type responses that all oil related questions get - some say "yes" and some say "no". Based on my personal experiences with using motorcycle oil in non-wet clutch engines (Ducati 748R which I endurance raced for three season and my 930 - both engines which I overhauled at one point), the answer is no, there is no downside. Obviously, mine is a very limited experience base, however.
Old 07-25-2013, 08:29 PM
Kevin,
My understanding is that the V-twin Mobil 1 lacks the friction modifiers present in the normal Mobil 1 for cars. So, without the modifiers, I guess you could expect a slight degradation in fuel economy. The normal Mobil 1 in the 15W50 viscosity still has the elevated ZDDP that our flat tappet motors need. Or, if you go to Mobil 1 Racing oil, all the viscosities have the elevated ZDDP levels.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 07-25-2013, 11:07 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Regualr Mobil 1 15 /50 has 1350 ppm Zinc
V-twin has 1750 ppm Zinc
Brad Penn has between 1200- 1500 http://www.penngrade1.com/Zinc.aspx
Flat tappet engines need 1400-1500 ppm zinc
Chris
Old 07-26-2013, 05:23 AM
Brad Penn has between 1200- 1500 Penn Grade 1 High Performance Oil
Chris
Chris,
You are generally accurate on your comments on zinc. What needs to be added is that most oil suppliers have cut the ZDDP levels from 1300-1500 ppm to levels around 650 - 750 which appears to be unsatisfactory for our flat tappet motors.
If you are in the market for 15/50 oil, then I question that the Mobil 1 formulation isn't a good choice, even though it does not quite meet your criteria of 1400 ppm for zinc.
In reality, whether you run Mobil 1, Mobil V-twin, Motul, Joe Gibbs, Total or some other brands I may have left out, it will come down to availability and cost. All these oils are expensive and may not be readily available. And, all thanks to the USEPA for creating this dilemma for people with older cars.
Ernie
Old 07-26-2013, 07:16 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Thanks for the tips on the V-twin formulation. Sorry for the sidetrack but I thought i'd ask since the mention of it came up.
I'm going with the Chevron Delo 400 for my motor when it's done. If it's good enough for Henry, good enough for me! Already got two boxes (6 gallons) on hand from Costco!!!
Kevin L
'86 Carrera "Larry"
Old 07-26-2013, 07:28 AM
CBRacerX's Avatar
Thanks for the tips guys. Just got six 1 gallon Delo 400 30w jugs from Amazon. Let the engine break in begin.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 02-10-2015, 05:22 PM
Here are the numbers. Note that all the break in oils have triple the zinc.
1. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
ZDDP= 3000 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
2. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
ZDDP = 1500 ppm
NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use.
3. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
ZDDP = 1500 ppm
4. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
ZDDP = 1100 ppm
5. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
ZDDP = 2100 ppm
6. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
ZDDP = 1400 ppm
7. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
ZDDP = 1000 ppm
8. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
9. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
ZDDP = 1500 ppm
10. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
ZDDP = 900 ppm
11. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
ZDDP = 1200 ppm
12. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
ZDDP = 1300 ppm
13. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
ZDDP = 1100 ppm
14. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
15. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
16. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
17. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
18. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
ZDDP = 1500 ppm
19. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
20. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
ZDDP = 1600 ppm
21. 15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1133 ppm
phos = 1,168 ppm
ZDDP = 1100 ppm
22. 30wt Edelbrock Break-In Oil conventional = 69,160 psi
zinc = 1545 ppm
phos = 1465 ppm
ZDDP = 1500 ppm
23. 10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
ZDDP = 100 ppm
24. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
ZDDP = 1300 ppm
25. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
ZDDP = 1500 ppm
26. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
ZDDP = 1100 ppm
27. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
ZDDP = 2100 ppm
28. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi
zinc = 2436 ppm (up 1848 ppm)
phos = 2053 ppm (up 1356 ppm)
ZDDP = 2200 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
29. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
ZDDP = 1100 ppm
30. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
ZDDP = 1900 ppm
31. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi
zinc = 1673 ppm
phos = 1114 ppm
ZDDP = 1300 ppm
32. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
ZDDP = 1300 ppm
33. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
ZDDP = 2400 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
34. 10W40 Summit Racing Premium Racing Oil, API SL conventional = 59,483 psi
zinc = 1764 ppm
phos = 1974 ppm
Claimed ZDDP level on the bottle = 1800 ppm
NOTE: Summit discontinued this line of oil, as of spring of 2013.
35. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
ZDDP = 2500 ppm
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
36. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
37. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
ZDDP = 2800 ppm
38. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi
zinc = 1565 ppm (up 573 ppm)
phos = 1277 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
39. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi
zinc = 1680 ppm (up 573 ppm)
phos = 1275 ppm (up 517 ppm)
ZDDP = 1400 ppm
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. Buyer beware.
40. 30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
ZDDP = 4000 ppm
Old 02-11-2015, 02:33 AM
cmcfaul's Avatar
The Mobil 1 V twin stuff is $14/ qt expensive. I usually mail order it through Amazon. Some times it goes on sale locally.
A real V-twin has the transmission and clutch separate from the engine (attached by a fat belt). I question if the Mobil V-twin oil is designed for a wet clutch environment.
Chris
Old 02-11-2015, 10:03 AM
This could quickly morph into another 50 page oil thread, so let's keep this topic to "break-in lubes".
GM's EOS additive (now marketed as AC Delco Assembly Lube) is widely used on engines, for break-in as well as long term. Here's some discussion about it:
E.O.S (Engine Oil Supplement) | Oil Additives | Bob Is The Oil Guy
Sherwood
Old 02-11-2015, 10:33 AM
So should one conclude from post 50 that the Lucas 30wt is the best oil for break-in due to the very high concentrations of ZN, Ph and ZDDP?
Old 02-11-2015, 11:01 AM
Just curious where you got all the data from post #50? Also how was it determined?
Thanks, Paul
1979 SC
"A man of many projects and too many hobbies"
Old 02-11-2015, 05:56 PM
Under the radar
Trackrash's Avatar
What about this stuff?
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-31-2015, 05:38 PM
I believe Porsche,AMG,Corvette and etc use Mobil 1 from the get go. I have disassembled quite a few air cooled 911 engines and have yet found any tappets (my MG has 8 my 6 has 0). The 20 min cam break in? The main reason is flat tappet engines need the oil splash from the crankshaft to lube the cam.
Old 12-17-2015, 07:25 PM
True, our P engines do not have tapperts or lifters in the traditional sense. But, the rocker arms are lifted directly by the cams, so there still is the same sliding kind of motion that there is in an OHV engine with flat bottom lifters. If you contrast that with, say, the valve train of an LS engine with its roller lifters, you cam see why people desribe a Porsche six as a "flat tappet" engine.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 12-18-2015, 04:52 AM
Senior Advisor
James Brown's Avatar
get this, done
08 Cayenne Turbo
Old 12-18-2015, 06:39 PM
break in oil.
Hi,I have always used Valvoline non-detergent straight 30W for the first 500 miles.Then do your leakdown te full st to determine ring seatage.No full throttle at first 500 miles.
Old 12-19-2015, 08:47 AM
JOHN21BLACK's Avatar
Henry, My mechanic used Valvoline VR-1 20/50 for break in. Was told to change after 1,000 miles. Have not put any miles on new rebuilt yet, only been starting for 30 min at a time while I do my brake upgrade and bushings replacement. Was told it would be fine to stay with the VR-1 20/50, but should I go to the Delo 400 SAE30 after the 1,000 miles?
Old 12-28-2015, 02:36 PM
