rkeele's Avatar
Been using Total racing 20-50 any opinions or numbers
Old 01-03-2016, 11:04 AM
rkeele's Avatar
I was told by a SC oil dist. and the latest is Diesel Oil is no longer optimal for air cooled motors , they have reformulated it for the new catalytic converters in the new diesels, also told that by 2 diff. mech. that I know.
Old 01-03-2016, 12:45 PM
That's interesting; as I understand, the primary difference between older CI-4 vs CJ-4 oils is the ash content (which acts to obstruct diesel particulate filters). CJ-4 oils still have fairly high zinc and phosphorous levels; for example, Chevron Delo 400 LE 15W-40 (CJ-4) has ~1200 ppm P and ~1300 ppm Zn. Non-LE Delo 400 15W-40 (CI-4) has ~1400 ppm P and ~1500 ppm Zn. As Henry's comments were from a few years back, I wonder if he still goes with Delo?
Paul
1982 911SC
Old 01-07-2016, 04:31 PM
rkeele's Avatar
good question he said he uses the LE which has lower numbers, Total racing is different than non racing has more zddp from what I was told.
Old 01-11-2016, 09:41 PM
VFR750's Avatar
Oil Analysis by ANA Labs.
Oil Analysis performed on oil bought in mid-late 2015
20W50 Valvoline VR-1 Conventional Racing (Silver bottle)
Zinc: 1177 ppm
Phosphorous: 1281 ppm
20W50 Castrol GTX Conventional (Yellow bottle)
Zinc: 1074 ppm
Phosphorous: 816 ppm
I thought the 20W50s were not subjected to the required drop for the SN rating. Well it turns out Castrol GTX is off my list. The 20W-50 actually tested out as only a 40W at 100C test conditions. It's really only a 20W-40....
Even VR-1 now seems a little low.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 01-29-2016, 12:28 PM
subscribe
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-09-2016, 04:40 PM
Alan L's Avatar
Originally Posted by Henry Schmidt View Post
I understand that the Porsche world loves Brad Penn but we're seeing some of the worst results (wear) in engines that use exclusively Brad Penn. We're using Delo 400 in everything.
Henry - would the SAE 30 recommendation apply to turbo as well (930) - break-in and track use? I've got to break my engine in shortly - because the last lot of rings never seated in the deglazed bores.
New P/Cs this time round.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-09-2016, 10:20 PM
1978 911 SC
Been searching and decide to bring this thread back to life... (without starting a debate) Interested in current thoughts on break in oil itself. I have a new complete rebuilt engine ready to start soon. Locally I can get Lucas Oil SAE 30 Break in oil. This is the Data specs. Thoughts...
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler.
Old 02-23-2023, 11:06 AM
Racer
winders's Avatar
I recommend Driven break-in oil. I am going to use Driven BR40 to break-in my new race engine on the dyno and then switch to Driven XP6 once broken in.
I believe Driven BR is the 30 weight version of their break-in oil.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-23-2023, 11:48 AM
1978 911 SC
Interesting. Never heard of this brand. I will have a look and read up. Not sure if it's available locally in Canada. Cheers
Old 02-24-2023, 09:43 AM
Racer
winders's Avatar
Driven is spectacular oil.....very well regarded in the racing community. Not cheap....
Scott Winders
PCA GT3 #3
Old 02-24-2023, 11:28 AM
Jeff Alton's Avatar
It is available... Mopac Autosupply and Lordco both carry it, though I am not sure of the availability of all different part numbers.
Cheers
www.turn3autosport.com
Old 02-24-2023, 12:30 PM
I’m a bit of an oil nerd. I have looked into the Driven range and it is pretty impressive. Also, available in Australia fairly readily - probably going to make the switch next oil change.
Old 02-24-2023, 02:45 PM
1978 911 SC
Cheers
Thanks Jeff! I will go to Lodrco and inquire. Cheers !!
Old 02-24-2023, 03:49 PM
Emo993's Avatar
Driven Oils, developed by Joe Gibbs Racing. Lots of Nascar titles/wins with lots of oil development. Just a great oil for our air cooled engines. Best, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 03-06-2023, 07:50 AM
PCA Member since 1988
About 7 years ago, I was at Carlisle for a weekend Ford show. Joe Gibbs Driven had a tent set up. The presentation was given by their chief engineer (I forget his name). The main point of his presentation was to NOT use any aftermarket oil additives, and just as importantly, why. It turns out that there are several dozen different formulations of ZDDP, "zinc," or whatever name you use, as well as the other additives (detergents, friction modifiers, etc.). The oil additives have to be designed to work together, so that the one does not interfere with the other or actually cause it to precipitate out. Then you end up with less ZDDP or other additives than you started with. Therefore, don't user any oil additives. But you already knew that.
Of course, when you have access to a guy like that, you hang around after the presentation and ask more questions! It was a fascinating discussion, all the details of which I can't fully recount, but some important points: the highest pressure and wear points in an engine typically are the cam and follower contact, and the rocker to valve stem. These places have high loads that concentrate in a line or even point, with a wiping motion that tends to wipe off the oil film, so ZDDP is crucial at these points. Newer engines are designed with roller followers on the cam in order to reduce these point/line and wiping motions, because EPA regs have increased the time that emissions systems must be warrantied, and the zinc poisons catalytic converters, so in newer oils the ZDDP had to be reduced, forcing the followers to be redesigned toward with less of it.
Another important point: The break in occurs in the first 100 miles, usually much less, because engines are now manufactured to tighter tolerances, and the cylinder wall finishes are smoother, so the rings seat sooner. In addition, most new engines are now test-run on a dyno before they go in the car, so that part of break-in already occurs before a new vehicle even reaches the customer. The journal bearings (mains, rods, and cams) should not break in, because they should always be floating on an oil film. Some other parts may see high loads, such as timing gears or chains, but usually not if well-designed. Driven offers a break-in oil, but he said that for new cars and trucks it's not necessary. If you are building a racing engine with cast-iron and rougher cylinder finish or using older cams and lifters, then use it.
Well, as everyone now knows, our old air-cooled 911 engines weren't designed for low-zinc oils, so we want to find oils with high ZDDP levels. Diesel rated oils became the initial go-to oil for the older hobbyists, because diesel engines didn't have catalysts until recently, so they had higher levels of it. However, as most of you also know, in recent years, diesel engines have been fitted with catalysts and Diesel Particulate Filters (DPF), and consequently the zinc levels have been reduced somewhat. So just picking any old diesel rated oil no longer guarantees high ZDDP.
To further complicate things, the oil manufacturers change their oil formulation from time to time, and don't make widespread announcements about it. It's not a trade secret, but you have to go to their websites and look up the oils and see whether anything has changed recently.
Since that's a PITA, I've been using the Ford Motorcraft brand 15W-40 diesel oil for Powerstroke Engines. I don't have the experience that some of you do with building 911 engines for decades and seeing how long they last and what wears out, or what wears out in racing, so If you have good results with a particular oil, I won't argue. But I chose the Ford Diesel stuff because it says right on the bottle, "Contains more than 1000PPM of phosphorus (that's the P in ZDDP). Not for use in catalyst-equipped engines." Yeah, that sounds like the good stuff to me. I was using Delo for a long time, and still use it in some other old cars, and I can't say I ever had a problem with it. But the label on the bottle doesn't tell you much. So I lean towards the Ford Diesel stuff. Especially when it's on sale at Walmart!
Anyway, some things to think about when you go shopping for oil. And if in doubt, check the web site for the oil manufacturer.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-06-2023, 06:12 PM
