Assembling Oil Temperature Regulator
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods Last edited by 930/66; 08-09-2014 at 02:03 AM.. |
Vent Cover
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Assembling New Turbocharger Oil Feed Line Set from TurboKraft
Installing Air Guide Plates
Assembling Zylinder Heads
Assembling Zylinder Heads and Camshaft Housing
Preparation Chain Housing / Assembling
Befor Assembling the Chain Housing i have to preparation it.
The Sealing Kit from Supertec has everything you need! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Assembling 964 Camshaft and End Cover
Installing Camshaft Sprocket
Installing Patrick Motorsport RSR Flyweel
Installing D-Zug Pulley
Checking Parallel of Sprockets with Stromski Racing Tool
I Think for a DIY is the Tool from Stromski Racing helpful
Installing End Cover for Intermedia Shaft
Installing Chain on Sprockets an fix it with the Chain Sprocket Holder
Rennch on YouTube
It's on my bucket list to rebuild a Porsche engine. This seems so complicated, and beautiful at the same time. Fantastic job.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Great attention to detail on the build, and well-lit photography.
I remember when those 3.4 cylinders came up for sale and I started daydreaming about picking them up. Glad they went to such a fine home! Ken
Ken 1986 930 2016 R1200RS |
the conversation from 3.3 to 3.4 was many jears in my Head!
Thanks for your kind words!
Installing Rocker Arm with new Rocker Arm Shaft
Installing Rocker Arm (with new bushings) and new Rocker Arm Shaft.
I also ordered the Rocker Shaft Lock Set and the Rocker Shaft Seal Set : Porsche Motorsport from Chris TurboKraft. Bolts from the Rocker Shaft and some Adjusting screw and nuts are also new. ![]() ![]() ![]() ![]() ![]()
Assembling Rocker Arms in the Camshaft Housing
