Installing Elbow Hose and TK Adapter LLK
Installing Elbow Hose and TK Adapter LLK:
![]() Installing 4-Speed Transmission: ![]() ![]() Change OEM Starter to High Torque Starter: ![]() ![]()
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
Awesome thread. Beautiful work! |
Installing Engine to his right Place
Assembling K27/29 Hybrid from Rarly8
Installing Rarly8 Headers and Turbocharger
Installing Tial Wastegate F46 Narrow Version
Tial Wastegate with 0.4 Bar Spring:
Zeitronics ZT-II O2-Sensor
Installing Heater Hoses / Muffler Bracket
LLK from TK Preperation for Installation
Installing Boost Control
So i have 2 Settings 0.4 and 1.0 Bar of Boost.
The rear Wiper was removed and now i have the possibility to take the Rear-Wiper Switch to switch the valve.... ![]() ![]()
Installation / Problem LLK
First i must say the Parts look good and the Customer Service from Chris is nice!
The Intercooler-Kit had 3 errors: #1 conflict with the air filter box #2 connection to supplementary air slide wrong #3 Connection to the turbocharger intercooler welded wrong (can`t close my tailgate) I have changed the air filter box and cut the connection for the auxiliary-air device #3 make my Welder right. Chris send me the reimbursement for that, Thanks Again! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
I have to admit, the engine stand scared me a little
![]() Glad it is in its proper place with no mishaps. Great work. |
No soft or plastic jaws for the bench vise? ts ts ts
![]() But anyway, nice thread
Roland 930 Turbo '81 Too many modifications to list |
More stable than it looks
I know he does not look stable
![]() but better for engine and vehicle to use my unstable look stand as a normal jack
Roland you're scaring me, you see everything
But I do not say something every time I see
Installing Oil Trip Tank from GSF / Final Installation Exhaust System
Oil Trip Tank, Adapter and Oil Line from GSF:
![]() ![]() ![]() ![]() Muffler 76mm Diameter: ![]()
Exhaust Wrap
Zeitronics ZT-II Installation
Zeitronics ZT-II (under Driver Seat)
- Zeitronix LCD Display - Black Box Data Logger - Wideband Air Fuel Ratio Meter - Boost Sensor - RPM Signal logging - Knock Sensor ![]() ![]() ![]() ![]() ![]()
Hello 930/66,
To avoid of installed(settled) this thermal protection there is another solution than I envisage seriously, that to make a ceramic treatment(processing) on the collector of escape by the company Zircotec, it is not given but do not apparently very effective. I have just joined but I am your restoration(catering) for a long time as that Spenny-b, bravo, your work is great(tremendous)!
