jkh2cpu's Avatar
Rod Bolt Clearance Problem...
So I'm sweating away in the garage, building the crankshaft. Half
the sweat is anxiety: this is the heart of the motor, right? I've got
six rod bolts left from an experiment, and a new package of rod bolts.
The six old ones go in OK, and when I start with the new package,
they won't go... not with a screw driver handle tap, and not with
some light hammering with the end cap safely resting on wood. I
do manage to get them out with a few minutes of tapping, with the
end cap resting in my hand. (later I try this rod out with old bolts,
and it still fits nicely on the crankshaft, so I assume no damage done.)
After my irritation subsides, I get my micrometer out and do some
measuring. The rod bolts that fit measure in the range of 10.18 -
10.19 mm, while all 12 new rod bolts measure 10.21 to 10.23 and
of course they don't fit with vigorous whacking and smacking.
I don't suppose there's some magic fix for this except to send them
back and expect to get better fitting bolts next time.
Any suggestions out there?
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 08-01-2015, 09:06 AM
