Supertec 10-mm x 1.25 cylinder head stud torque spec......
Deleted. Henry sent me the information.
Tony
Old 10-08-2016, 04:24 PM
silver911rdb's Avatar
Any chance you can pass along? I'm assembling my engine with supertec studs as well. Looking for info on which thread lube to use and also torque spec
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 04-15-2017, 07:56 AM
Chain fence eating turbo
Did yall lose the spec sheet?
Old 04-15-2017, 11:22 AM
Previous owner had the engine built. I'm rebuilding the engine and have no documentation
-Rich-
1984 911 Track
Old 04-15-2017, 04:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
SUPERTEC PERFORMANCE HEAD STUD KIT INSTALLATION INSTRUCTIONS
1) USE BLUE LOCTITE ON CASE END (10 x 1.50)
2) WE SUPPLY SUPERTEC THREAD LUBE WITH EACH KIT BUT YOU CAN USE LIGHT
WEIGHT MOTOR OIL OR ANTI SEIZE ON CYLINDER HEAD END
3) CLEAN CASE THREADS COMPLETELY
We recommend a thread forming tap (1.50x10 PD-6 6-N) for this application
4) TO INSTALL STUDS, DOUBLE NUT WITH THE GOLD NUTS PROVIDED
5) INSTALL STUD UNTIL IT BOTTOMS AND TURN OUT 1/4 TURN
******DO NOT FORCE THE STUDS INTO THE CASE*******
6) INSTALLATION LENGTH IS NO LONGER RELEVANT
TORQUE SPECIFICATION + or – 2lbs STANDARD TORQUE PATTERN IS MAINTAINED
a. 2.0 aluminum case 30 lb/ft
b. 2.0, 2.2, 2.4, 2.7 ( all magnesium cases ) 26 lb/ft
c. 3.0, 3.2, 3.6 aluminum case 30 lb/ft
d. 3.0, 3.3, 3.6 aluminum Turbo 32-36 lb/ft
THERE IS NO RETORQUING NECESSARY
Henry Schmidt
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-15-2017, 05:05 PM
Henry Schmidt
Ph: 760-728-3062
Old 04-15-2017, 05:10 PM
Thanks!
-Rich-
1984 911 Track
Old 04-16-2017, 06:50 AM
