Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW General Discussion
poorshe911's Avatar
528it ABS problem
I have a 2000 528it that energizes the ABS system on a dry road. When I start the car, no 'ABS Brake' light is on the dash but when the brakes are applied the ABS system comes on pulsing what I think is a front brake. Then the 'ABS Brake' light comes on along with the Stability Control light and the ABS system stops working and I have good normal non-ABS brakes.
I'm guessing it's a wheel speed sensor that failed.
Can anyone help me with a test procedure to diagnose a bad speed sensor? Do you think it may be something else?
Thanks,
Michael
'99 323
'00 528
'83 911SC
Old 01-13-2005, 02:27 PM
ruf-porsche's Avatar
you should be able to get error code if you have a OBD II scanner, or take it into the stealer and pay them to read the code for you.
Old 10-06-2005, 09:46 AM
