-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/forumdisplay.php?f=24)
-   -   HP2 Sport Mirrors (http://forums.pelicanparts.com/showthread.php?t=440595)
Maddmike 08-30-2018 06:39 PM
Originally Posted by Alfa145V6 (Post 10162938)
Mike, from memory you will need to drill through the rubber gasket to have new holes in the correct place. Once fitted the gasket is not totally flush with the bodywork as the bodywork is slightly curved. So a gap is clearly visible. Can you post a photo and we can say if its as it should be?
It has been commented on before on Pelican and its unfortunate I guess , but it’s splitting hairs really as now you can see behind you!
Did you exercise the ‘break out’ before fitting them? It was recommended on the instructions from Sandbar due to the bodywork of the HP2 being not so strong as the S1000RR.
Yes, I broke them back 10X each and then re-tightened.
My issue is that one side is too short and doesn't cover the bracket while the other side is way too long. I tried trimming one but that was not successful either and I may have just ruined it.
I will try some pics tomorrow.
JT_R1200S 08-30-2018 06:53 PM
I ended up using a set of Mirrors from Kiwav motors out of Taiwan. They have really quick shipping if you pay the extra $10.
https://www.kiwavmotors.com/en/parts/controls/mirrors/fairing-sportsbike/medusa-sportsbike-mirrors-detail
https://kiwav.com/kiwavebay/product/01/mirror/MedusaMX/medusaMX-sportsbike-size.jpg
The 6mm bolts shipped with them would not quite fit as the bases are just a hair tight, but using 5mm bolts worked. They were like $100 for the pair.
-Jim
Alfa145V6 08-31-2018 05:10 AM
Ah, that’s a bit of a mystery then. Both my rubber boots were straight forward enough to fit and I didn’t notice any difference between them. Too late to have them side by side to compare?
NZHP2 06-13-2020 03:27 PM
Has anyone got access to the mounts szazbo was making? Late to the party I know, but sick of looking at me elbows!!!!
Droptarotter 06-13-2020 04:16 PM
Just responded in your other post.
Cheers
Fede 07-23-2023 06:47 AM
Hello from Italy :)
is it still possible to buy the Szazbo mirror kit?
Many thanks!
Fede 07-31-2023 03:04 AM
Can anyone help me?
wswartzwel 07-31-2023 04:51 AM
Szazbo hasn't posted here in 5 years. You might try sandbar composites. he mentioned in one of his posts that they were selling his stuff.
Droptarotter 07-31-2023 05:54 PM
Originally Posted by Fede (Post 12050610)
Hello from Italy :)
Many thanks!
Both Szazbo and Sandbar are not selling the mirror kits anymore. There are a couple of HP2 forums on Facebook where you might get some ideas?
I think one of the easiest adaptations was to get the 1000RR mirrors, cut off the mounts and drill new bolt holes to align with the HP2 fairing holes.
Good luck!
Fede 08-02-2023 09:58 PM
Many thanks of you for the replies...I knew it would be difficult.
I will follow the modification of the mirrors for RR :)
