-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/forumdisplay.php?f=24)
-   -   Bags Connection tank bag on HP2 Sport (http://forums.pelicanparts.com/showthread.php?t=658644)
szazbo 02-16-2012 05:05 PM
I recently installed the Bags Connection tank ring and adapter on my HP2 Sport. There are actually two different rings depending on the year of the bike. I believe that the ring is shared with the GS also. I used the bolts and nylock nuts provided in the kit. So you bolt together the ring and gas cap ring, transfer the gas cap and reinstall this onto the tank. I noticed when tightening the torx screws inside the filler neck that the ring seemed like it was sitting higher than before.
Went out to the garage later and smelled fuel. Ok there are 4 bikes in there so that might be possible but the smell was around the Sport. Using my sniffer I noticed that around the gas it was the strongest.
I removed the tank ring again trying to see what the issue was. What happened was that the nylock nuts were deeper than the tank ring and when bolting the assembly on, contacts the carbon center tank section lifts the gas cap up from the filler neck. There were witness marks on the carbon that even after a day were deep.
Solution was easy. Replace the bolts with some stainless bolts and standard nuts. I cut the bolts shorter and used locktite on the nuts so they were flush with the tank ring. Everything went together smoothly from there with no tension on the screws. I also had the tank adapter ring painted to match the gas cap as the stock color that it comes in is not even close.
This is a great solution for a tank bag for the sport and there are several bags to choose from depending on your needs. Looks ok also.
http://forums.pelicanparts.com/uploa...1329444268.jpg
SergioK 02-16-2012 09:01 PM
Which bag did you go with?
jaytee 02-16-2012 10:45 PM
I use this system on the R12S as well and love it. I use the teeny-tiny bag and find it perfect for a rag, med can of plexus, earplugs, wind proof underwear top and bald-spot cover (aka baseball hat). If I need more room to carry thermal bottoms or a pair of bottled waters I unzip the expansion zipper. Nice!
szazbo 02-17-2012 09:13 AM
Bags Connect Daypack II
I used the Daypack II on the Sport. In this photo it is in the expanded position. I also use it as a tailbag on my Megamoto. It has plenty of room to put tire repair kit, jacket liner, water etc. I also have a Engage Sport for the weekend run. THis will hold enough for 2 days.http://forums.pelicanparts.com/uploa...1329502422.jpg
Droptarotter 02-17-2012 09:27 AM
Yep, I have the same system. I did not have any problems with the mount.
I usually put my compressor, tire repair kit, Lemon Pledge, rag and if needed an electric vest into that little bag.
I also have the Engage XL bag if I need more storage.
Cheers
SergioK 02-17-2012 09:42 AM
I think this is the cleanest solution so far. I have it on my GS and it never occurred to me that they had one for the HP2 Sport.
Steve Carlton 09-06-2012 09:03 PM
Does BMW make a tank bag for the HP2S?
SergioK 09-06-2012 09:30 PM
Yes
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/424568-hp2s-factory-tankbag-help-other-side-pond.html
Steve Carlton 09-06-2012 09:47 PM
Hmmm... interesting. Is it expandable? Anyone have a picture of it on a bike? I may not fit a DSLR in there, but I gots alternatives...
Guyf 09-07-2012 03:42 AM
I have the factory tank bag. Bought it from Max BMW on Amazon. It is very small and not expandable. A thin jacket liner is all that will fit there. Not worth it in my opinion.
You can fit a standard garmin car GPS in the clear window, so if you want to use it a a cheap GPS mount solution, then it's ok.
BMW HP2 TANKBAG : Amazon.com : Automotivehttp://forums.pelicanparts.com/uploa...1347018158.jpg
http://forums.pelicanparts.com/uploa...1347018169.jpg
SergioK 09-07-2012 05:45 AM
Steve, go with the tank ring mount solution. It's much more functional plus you can buy expandable bags that fit your need. Forget the OEM bag.
Steve Carlton 09-07-2012 06:08 AM
Well, here's my thoughts.
- I don't need to carry much, and I'm not picturing this a long-range bike. I have small cameras.
- I used to put my radar detector under the map window of my other bags; like that setup because I can take the detector off the bike with the bag.
- it sits in front of the gas cap, so no hassle there.
- it's cheap, so I could always do something else.
SergioK 09-07-2012 06:31 AM
The only cameras that would fit are P&S... no way a DSLR is getting in there.
shreddr 09-07-2012 06:39 AM
does that get in the way of viewing the instrument cluster?
I just use a fanny pack for my tools and whatever for day trips. If i am going over night I have the BMW tail bag although I have never mounted it up to the HP2S, I certainly wouldnt want to scuff the paint! :eek:
szazbo 09-07-2012 07:40 AM
Tank Bag
There is no problem with viewing the instruments with this tank bag at all. The expansion of the bag is about 2 inches as shown in this pic. I have a Cycle Pump, plug kit, soft tie down extensions, key for the seat, and my jacket liner in it in this photo. There is also a zipper pocket on the top to carry a SPOT or something small if you want. I repainted the Bags Connection metal ring that is around the fuel cap to match the OEM fuel cap. It comes in a rattle can silver color and looks a little odd.
Steve Carlton 09-07-2012 11:50 AM
How about an ornery P&S with a big ass Foveon sensor?
http://forums.pelicanparts.com/uploa...1347047402.jpg
Steve Carlton 09-07-2012 11:53 AM
Or "full frame" 35mm film?...
http://forums.pelicanparts.com/uploa...1347047595.jpg
ckcarr 09-07-2012 12:12 PM
You're like me. You are trying to find a reason to buy the factory bag, because that's what you really want. So, just get it!
Steve Carlton 09-07-2012 01:26 PM
Yeah, I like it. Small, flat, $91. Except for carrying a DSLR, okay. I already ordered it from SJBMW. As well as the bar risers, the S1000RR mirror conversion kit, and the heated grips.
This bike better show up in good condition...
shreddr 09-07-2012 03:27 PM
Originally Posted by Steve Carlton (Post 6962053)
I already ordered it from SJBMW. As well as the bar risers, the S1000RR mirror conversion kit, heated grips and the full monty big bore top end parts kit from CP-Carrillo!.
awesome!:D
