Low Beam fine, High Beam too high
After I've adjusted my R1200S low beam properly, the high beam is way too high. Any ideas?
[Previously I had the problem where the vertical headlight adjuster jumped its tracks (the little sphere jumped out of its cup so that the adjuster doesn't do anything. I fixed that and the adjuster seems to work fine now.] Thanks |
Hi
I have the same problem - have You solved it ? |
I wanna Live 'til I die!
They do have separate adjusters... just saying.
I forgot, because it has been so long, but you may be able to take the HL assembly out and adjust it within.
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
unsafe at any speed
One is for lateral and one horizontal.
Adjusting headlight • Motorcycle on level surface. • Rider’s weight on motorcycle (approx.80 kg/ 176 lbs). • Move swivel lever to horizontal position (basic setting). • Turn the adjusting screw to correct the headlight beam throw. Lateral adjustment: ....................... Adjusting screw on left of headlight. Vertical adjustment: .....................Adjusting screw on right of headlight. Turn screw anti-clockwise:............... longer throw Turn screw clockwise: ..................... shorter throw Setting: .... -12 cm (-4.7 in) over a distance of 10 m (32.8 ft)
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Bill... YOU ARE BACK!
Last time I saw you, you were in someone's computer somewhere in Australia... looked like you were trying to get out... Glad you made it.
unsafe at any speed
Joergen, Signit98,
Not solved yet. I'm going to try Signit's suggestion of trying to manipulate the hi beam internally/independently - maybe there's something not seated right entirely withing the high beam assembly. (Or maybe my repair of the adjuster was incomplete.) [Trouble is, on the R12S nothing can be reliably done (except by a dextrous Pixie) to the headlights (even change bulbs) without removing the whole assembly.] Bill Swartzwelder: on the R12S the vertical adjuster is between the two beams and the horizontal is to the right of both, looking from aft. Question: I assume you were describing the adjustment for the R1200GS; was your "left/right of headlight" looking from aft or from in front of the bike? Thanks, Schwenn |
unsafe at any speed
Sorry I was thinking R1100S and pulled that from the r1100S service manual.
Tags |
beam , headlight , r1200s , r12s , throw |
