| Lowndes |
10-16-2017 06:00 PM |
Dave - if this is what you have on your front right caliper, you'll need to replace the strange barrel shaped thing on top of the caliper with a bleed nipple.
That fitting is for the assembly line filling of the front brake hydraulic system. It unscrews and a bleed nipple then goes in. Save yourself some mess and carefully tape the threads of the bleed nipple with plumbers tape. That will prevent the threads from weeping and bubbles from entering while you are bleeding or pumping the system.
DOT4 eats paint and plastic. Keep a wet rag handy. And drop a quarter (25¢ piece) in the handlebar reservoir to keep it from squirting on the dash and windscreen. Clutch side, too. That's the best 50 cents I ever spent on the bike. They're still in there.
https://lh3.googleusercontent.com/5v...3-h911-no?.jpg
