issue with a 2006 boxster s
Bought a super clean 2006 boxster s from a copart auction. I have an issue w the motor struggling to star.. it backfires and pops and just wont idle or rev past 1200 rpms.
Wondering if anyone has any suggestions.. I purchased the durametric software and I appear to have no engine codes.
Before I start spending money randomly, I was hoping that the boxster community could provide some ideas or guidance. I will try the following items.
Maf
Crank and camshaft sensors
Fuel pump
Spark plugs and or coils
Vacuum lines
And oil separator
Wondering if anyone has any other suggestions
CB
Old 06-17-2020, 08:59 PM
Vacuum leak?
Old 06-25-2020, 07:02 PM
anybody? was hoping that someone had run into something like this and had some insights of where to start
Old 07-04-2020, 09:31 PM
Check fuel pressure. Most of the other problems would cause codes but most of the time low fuel pressure won’t.
Pull a vacuum line off and spray carb cleaner in it while starting and see if it makes a difference.
How many miles on it?
Try unplugging the maf while it’s running and see if it changes.
Keep us posted.
Tony
Old 07-04-2020, 10:23 PM
Unplugged the maf, I'm starting to suspect a fuel pump or filter. The car has 72k miles on it and I have all the service records.
It is super clean.
I was just wondering if anyone had a similar experience and could provide some insight on troubleshooting
Old 07-05-2020, 11:05 PM
If it's running that bad, you have to have an engine code. Codes are the starting point so you're not guessing and throwing lots of $$$ at those guesses.
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 07-07-2020, 06:06 AM
no codes. used Durametric and no check engine light and no code. pretty sure its a fuel pump. taking a fuel pressure reading later tonight.
Old 07-07-2020, 08:29 AM
Damn, got 50 psi at each rail... pulling the plugs tomorrow and checking the fuel pressure regulator and the wires/coils tomorrow
Old 07-08-2020, 10:36 PM
The car runs like hell and cant get above 400 rpms without stumbling and sputtering. Kicked out a cloud of gray smoke today
Old 07-08-2020, 10:38 PM
It'll be legen-waitforit
stealthn's Avatar
Check your gas cap
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 07-14-2020, 08:14 PM
Proud 944 Owner
83 944's Avatar
Sucks it won’t idle and no codes. So no live running data. Any freeze frame data? On a possible event failure captured? My Autel can usually get history data before clearing faults and freeze frame at time of fault. Being from an auction the car could have been tampered with. Pulled fuses or replays, things unplugged. Ground disconnected. Start at the basics, air, fuel, spark, compression. If it has those 4 things mechanically speaker you’re good.
Old 07-18-2020, 05:50 AM
