Question CEL again
Well after a replacement MAF was installed 50 miles went by and the CEL came on again. This time the code that was there was P1128 I have read that this might be a bad oil filler seal. I checked the seal and it seemed fine. What all should I check? Thanks in advance.
And the Plot thickens. Today right after startup driving up hill I hear to loud thuds behind me and the CEL starts flashing sad.gif. So I turn around and coast into my driveway. Hook up the code scanner and find codes P0300 P0301 P0302 P0303. Telling me that there is a misfire in the cylinders 1-3. so to see if this keeps up I cleared the codes and restarted the car with no noticable misfires everything seems fine now. Any ideas what on earth could cause this? Thanks in advance.
86 BMW 535i
07 BMW X5
gone but not forgotten
1999 Boxster
Old 11-16-2004, 07:52 PM
AFJuvat's Avatar
Rolla,
P0300 - Engine misfire - damaging to catalyst
P0301 - Misfire, Cyl1 Damaging to catalyst
Etc..
Doi not dirve the car with that condition. You will cook your cats.
I would suggest first thing to do is disconnect your battery for 15 minutes or so - this will clear the adaptive memory from the DME. seeing as you just had your MAF; if this continues to be a problem, I would suggest removing your air filter and checking the airbox\intake pipe for dirt\debris. It is also a possibility that you have a faulty MAF
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-23-2004, 08:12 PM
