interior light problem
The only time the interior lights come on in my 2000 Boxster S is when the engine is running and a door is opened. Or if I turn the switch on at the light.
Shouldn't they come on when the car is unlocked? Door open, engine off? Is there suppose to be a light in the trunk? Is this a possible fuse problem? Thanks
Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head |
Will the light come on when the key is turned on and the door open but the car is not started or running?
Yes, key on, door open, engine not running, interior lights will come on?
good question, i have the same car 2000 S and the same problem. a shop had the car for 3 days b4 i had 2 take it back. they were unable to diagnose in that time.
'00 Boxster S '05 Prius '88 Landcruiser |
If you need to turn the key on for the interior lights to work is usually a sign the car is still in the transit mode. When the car is shipped the lights do not work without the key on to save the battery. During PDI they car is supposed to be taken out of the transit mode. Your cars might still be in the transit mode after all these years.
how do u get out of transit mode?
I'm guessing you have to take it to a dealer. I called the closest one (60 miles away) and could not even get them to call me back.
Probably a bad ign switch. You might notice a coule of other features that don't work when the key is out. Just a guess though.
