Ignition switch ????
My battery when dead due to the dash gauge lights remaining on after removing the key. I replaced the rear part of the ignition switch and it still behaves the same. If I use the remote to lock and then unlock the car the gauge lights go off ok. Also I noticed if the lights are on and I unplug the connector off of the ignition switch the gauge lights remain on.
Is this an ignition switch problem or something with the security system? 2000 Boxster S Carlisle PA |
i have a 99 boxster and am having the same problem any help?
Needs a compete ignition lock assembly, you keep your original key and cylinder.
Replacing the electrical switch only may not cure the problem.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
