Unable to open roof
I am unable to open my hood on 1998 Boxster, fuses have been checked but hood still won't open. Can anybody help ???
Old 10-16-2012, 01:02 PM
Zeke's Avatar
Roof? Hood? If the top, your e-brake switch may have failed.
Old 10-16-2012, 03:28 PM
roof failure
Thank you very much for your reply but what is an e brake switch ???
Old 10-17-2012, 10:29 AM
Emergency brake micro-switch that signals the top motors via a relay that the car is stopped and the brake applied and it is OK to open or close the top. So jiggle the e-brake handle. Possible to bypass via a relay pin bending hack. Or better yet, buy a specialized relay that always assumes you know what you are doing and doesn't require the e-brake to be engaged.
Hood is the term for Top over on the other side of the pond. It always helps to know where you are and the model year so we can help you better.
Old 10-17-2012, 11:09 AM
Thank you I will try this and post again
Old 10-18-2012, 09:54 AM
I had the same issue once. I was told to move the emergency brake handle up and down vigorously for a little bit and it worked great!
Old 10-18-2012, 11:07 AM
Thanks I have tried that but still having no success.
Old 10-20-2012, 06:17 AM
Is the ebrake light on the dash going out when you release the ebrake? Is it on at all?
Rob
Old 11-22-2012, 08:44 PM
