LN Engineering adaptor question
I have just purchased the LN engineering adaptor. My question is, does the oil need to be drained prior to installation of the adaptor. The oil was changed 400km ago when the IMS bearing was replaced. I am not sure if the oil level is above the entry to the filter or not.
Hope this is not a dumb question. Thanks. |
A small amount will come out with the filter -- but not much.
you should then be able to put the adapter on and the new filter type. might have to top off a cup or two of oil. m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
You will like the adapter and your engine will thank you for the increased measure of filtration; I've had mine since LN released it a few years back. As stated, you will loose only a small amount of oil, which you may then top up.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Thanks for the replies gents.
One more question. When bolting the adapter up tight, is there a specific torque figure required to ensure proper fitment?
Thanks again. |
If you could explain the increased measure of filtration statement that would be interesting. Did some one tell you that? The purpose of the adaptor is for convenience if you want to run a spin on. It is also to allow you to run an additional adaptor plate for an accusump. I have the complete set up. Fact is there is more K&N filter media in the drop in cartridge than in the spin on. Additionally you will have to cut open the spin on for media inspection. No big deal. Just need to understand all the trade offs. In-fact I am going to post all the individual components for sale soon. L&N spin on adapter, L&N accusump adaptor, install tool, accusump, braided line, pressure switch and maybe even the fittings. Not trying rain on your parade but some time info gets garbled in the transmission.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
How easy would it be to move the adapter from engine to engine?
I'm working on an engine test mule and want to have an accusump system in it. Is the adapter a simple "spin on" where the filter was? what size filters are you using with it? thanks, Mike
Use the Wix/NAPA Gold 1081 "Shorty" filter with the LN Accusump kit adaptor for the street, but plan on changing it more frequently due to reduced capacity. On the track, the longer 1042 can be used as ground clearances is not as much an issue...............
Thank you JFP...I don't make these comments up and rely on educated sources for the information, since I am not the "expert".
Your response coincides with the opinions of LN Engineering and Jake Raby, whom I consider the best sources of information on the M96.
I'm not sure there is really that much of a benefit to a screw-on... filtration-wise, that is. With the original filter I can easily inspect the filter for metal, that's a real benefit to the original filter system.
Plus, It's hard for me to imagine that the Porsche engineers haven't considered these issues (IMS bearing issues not withstanding!). Consider that we are running 9 quarts of oil, that's a lot... and not that big an engine. Also, most of us change about every 3,000 to 5,000 miles or once a year, whichever comes first. That's not asking too much of 9 quarts of oil, especially the high-end synthetics we all use. This filter thing seems like an unneeded expense to me. Steve |
Hope your engine doesn't end up baked, but to each their own. Every added measure of protection in my engine is worth the dime spent. Charles/LN Eng and Jake Raby didn't design and test these items because they thought they were trick or cool. The Porsche engineers were overruled by the accountants...that's why we have well thought out aftermarket components. I change my oil once a year, which typically does not exceed 2500-3000 miles...and I don't use M1 0W40.
In my case -- I plan for it to be 50% an engine tester -- so filtration is good here,
but will need to be street capable to log the miles. The other 50% of the time it will be a track car -- so I can switch back and forth on the oil filters. I generally run only 1 or 2 weekends before oil changes in track mode depending on whether its a DE or Race weekend. m
Steve |
Also, I can't see how it would have been cheaper for Porsche to use their stock system, so that argument is not too persuasive. Seems like a screw-on setup would have been the cheaper way to go. I don't meant to be snippy, please don't get me wrong. I'm just saying that I don't see the benefit of a screw-on filter over the stock. It's hard for me to believe that any benefit will ever be realized. Perhaps if we ran our oil 15,000 miles we would, but not at 3,000 miles. I just don't buy it. Steve |
Maybe the arguments for the filter adapter are:
Availability of cartridge filter Cost of cartridge filter Ease of replacement at any Jiffy Lube place once done Removes fear of that plastic housing getting screwed on wrong or cracked on reinstallation Better filter material in the spin on filters No bypass allowing oil to escape filtration as can happen in the stock system No need to clean out filter housing And do these benefits outweigh the costs of the initial adapter and its installation? Too many variables for me to tell. Is the every 3k miles I change the oil and filter guy gonna benefit? If he keeps the car for 10 years, that is 10 filters. As one who had to go back 3 times because the local quick-oil place screwed up the filter replacement on a Honda...curiously they have never had problems with my Boxster's original cartridge. Last edited by mikefocke; 12-22-2010 at 06:59 AM.. |
Cracked plastic housings, ripped paper end caps that allow total oil by pass, filter media pulled away from the paper end caps, again allowing total by pass, etc. The stock filter design is incredibly cheap to make, yet sells at retail for nearly three times what a high quality spin on sells for. Add in the 30% reduction in filter media pore diameter in the spin on filters, and you have a better made filter that cannot leak internally, without the plastic housing, and better oil filtration. Exactly where is the downside?
Accrochez-vous bien de vos rêves..........." |
Considering that many of us here change our oil every 3,000 to 5,000 miles if for nothing else but to inspect the filter media! Every time I've removed and inspected my old OEM filters they look just fine... I'm not saying failures don't occur, but I'm yet to see any evidence that these filters don't hold-up and or do their job. One can make anecdotal claims all day, but that's hardly scientific. I'd like to see some hard data that shows the benefit, that these engines show less wear due to a screw-on filter system over the OEM. If it makes you happy and you love doing this sort of stuff to your car, then by all means DO IT. |
Well, considering we often average about 75 to 100 oil changes a week, we open up and look at every filter, and provide used oil analysis for many of our clients at every oil change; I would hardly call my shop's opinions "anecdotal"..................
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 12-22-2010 at 02:16 PM.. |
