Chain Tensioner Replacement
As an off shoot of another post:
If I just want to replace the chain tensioners what steps would I have to undertake. Looking at Project 16 in the "101" book it would appear to me that all I need do is lock down the cam shafts after getting the crank to TDC and then just replace the tensioners. Or, do I have to go through all the steps of removing the cam housing, cams, chains, etc.?
Old 10-24-2011, 09:26 PM
harryrcb's Avatar
you need to get the crank to top dead center on the firing stroke and lock it with a pin. then put the correct cam tool on cyl 1-3 to lock the cams. 5 chain is the sing le cam lock tool, 3 chain is the dual cam lock tool. then you can remove the tensioners
Crazy Austrian
http://www.ws-ab.com
Old 10-25-2011, 10:04 AM
