Guest
Posts: n/a
The bolts holding in my locking mechanism are spline as they appear to be in your Figure 1. Do you know what size spline socket i require to remove the bolts?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Door Lock Mechanism / Boxster Door Handle - 986 / 987 |
Author of "101 Projects"
The "splines" you're referring to on the bolts are called Torx - they allow you to apply a greater amount of torque to a fastener with less risk of stripping. They are indeed a big improvement over standard hex fasteners. If you're going to be working on the car often, you should invest in a good quality set of Torx bits and drivers.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
