Tony (guest)
Guest
Posts: n/a
sorry to bother you again wayne but still cant find the bleed cap for the coolent to fill more coolant. I have taken of the filler caps oil n water and removed the cover but it just shows the metal bulk head not any bleed valve they are on the side not like your photo. Help were is it cant fill the coolant without bleeding system. 07 boster 2.7 engine thanks Tony
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Coolant Replacement / Boxster Coolant Flush - 986 / 987
Old 12-18-2011, 02:30 PM
Author of "101 Projects"
Wayne 962's Avatar
What you have here is a 987-2 style tank, which is used on the Cayman and 2007 and later 987 cars. There is no bleed plug on this one, you need to pull a vacuum on the system in order to bleed it. I probably need to do a tech article on this sometime in the very near future.
I would LOVE to see a how-to-do article on coolent flush/fill for the Boxster 987.2!!!!!!!!!!!
That is the next thing I would like to to on my car.
Chris
Austin, Tx
2010 Boxster
Old 08-02-2016, 08:57 AM
