rosiefish's Avatar
IMS won't pop!
I have not come up on this problem before! Doing an IMS replacement. Center bolt snapped. Using a blind bearing puller and the bearing won't budge. We have, however, managed to pull the vehicle a touch across the garage, while still on the jackstands, while attempting to remove this. Yay, brute strength. Any suggestions?
Old 03-26-2013, 02:39 PM
JFP in PA's Avatar
Not to sound pedantic, but have you removed the internal retaining snap ring? It should not take that amount of effort...........
Accrochez-vous bien de vos rêves..........."
Old 03-27-2013, 03:58 AM
rosiefish's Avatar
Hmmm
Well, it is a double bearing. I understand that with the single it is the clip style that lays on the top, but the double is inside and should pop when you pull.
I definately see this topic beaten to the ground in many forums, and asking for advice on it was a last resort. Makes me feel like an idiot because the IMS is discussed frequently. I just have not seen this issue come up.
Old 03-27-2013, 05:15 AM
JFP in PA's Avatar
Even with the internal style, it should not take the amount of force you are describing. Usually, they just release with a pop and the bearing comes out.
Old 03-27-2013, 10:26 AM
rosiefish's Avatar
I agree. Thanks for responding.
Old 03-27-2013, 11:36 AM
harryrcb's Avatar
get the LN engineering bearing puller it will work better than a generic puller.
Crazy Austrian
http://www.ws-ab.com
Old 03-28-2013, 08:09 PM
Me too
I have the same issue!
And yes I am using the LN bearing puller.
It is the early double row bearing with the internal snap ring.
the internal bolt broke so now I have resorted to a blind hole beasring puller. still no joy!
I have pulled one before so i am familiar with the process and the amount of force needed to overcome the spring type internal snap ring.
Suggestions?
2008 BOXSTER S LE
2008 CAYENNE GTS
Old 04-21-2013, 10:28 AM
Wow, not a lot of help here! Unlike the 911 forum.
I finally took a die grinder with a carbide burr to it and cut it out!
Left me a lot of clean up but progress has been made.
2008 BOXSTER S LE
2008 CAYENNE GTS
Old 04-23-2013, 06:59 PM
And people wonder why we no longer sell the IMSR kits retail for DIY installs.
Jake Raby
Flat 6 Innovations and Aircooled Technology
IMS Solution Inventor
US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369
'64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera
Old 04-30-2013, 05:28 PM
Are you saying you wouldn't give me a parts warranty on my DIY install?
Jake, you are exactly right. This repair should have been left to a pro!
I hope to get a few thousand miles out if. Didn't cost much, Learned a ton!
2008 BOXSTER S LE
2008 CAYENNE GTS
Old 04-30-2013, 07:55 PM
