Bell you are of incredible help! I took to your comment that i may be able to rotate the bank 4-6 cams 180 deg without pulling the valve covers or removing tensioner and came up with a plan. I was able to find a spot on the crank rotation (i think 90 deg from tdc) to get all 3 pistons at the most overall clearance which was about 3/4" from TDC each with one almost all the way back. I made a special tool by cutting a piece of steel plate to match cam groove shape and welding a nut on it so i could manipulate them from the back. This allowed me to remove cam plugs on back, mark the cams there, loosen the variocam and use my special tool to roatate the cam 180 deg while my buddy held the crank. I then tightened this cam, then i removed the 4 bolts on exhaust sprocket, rotated it with my special tool and locked it in at 180 deg. This got me close enough to get motor back to TDC and pin crank, loosen cams again, use rear plate to hold cams, then unpin crank, roll crank backwards a bit (towards U6) the. Roll back 100% into time and torque variocam and exhaust cam in place!
Here is the first crank in 4 years! I'm soooooo happy! Thank you So much and it didn't require even pulling the vakve cover!
https://youtu.be/96yUhjU6x7U
Old 12-26-2016, 11:09 AM
one of gods prototypes
bell's Avatar
glad to help........now go drive it
Brought to you by Carl's Jr.
Old 12-26-2016, 11:24 AM
Seems to be running well. Slight vibration right at 3100 rpms when not really on throttle (decel mostly or light throttle). But everything seems to work except stupid ignition switch! Uggh 24k miles and all these issues!
https://youtu.be/up1FG8xZnAA
Old 12-27-2016, 07:34 PM
bell's Avatar
that's right near cam changeover, any fault codes pop up? your snap on scanner should let you activate the cam solenoids to see if they are working properly....
how's the fuel trim?
cam deviation?
Old 12-28-2016, 04:07 PM
Tool
02 code finally popped up but it's because the driver cat was melted and I just completed the gutting of it until a new one comes in. No other codes. My brother has a new scan tool but it didn't pick up anything but the 02 sensor on 4-6 bank (driver's). I ordered a cat, just not here yet. I'll make sure I don't have any exhaust leaks as well.
Patrick Harris
1977 Porsche 911S: Racecar build - Follow @ www.patricksporschebuild.blogspot.com
1978 Porsche 911 SC: Petrol Blue, Steel Turbo Body, Black Interior, Sunroof. Another project.
1994 Toyota Supra Twin Turbo, 6 Speed, Hardtop, Baltic Blue (1 of 17).
Old 12-29-2016, 07:37 AM
Emo993's Avatar
Nice job bell, fun to see that kind of experience and friendly help....Best, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 12-31-2016, 03:44 AM
