IMS nervous
my 97 boxster, had its engine, go at 145,000k,s replaced with supposed low mileage used engine, wich is now at 180,000k,s , love the car but am nervous, am thinking of going newer, 2006 maybe, what was done to 06 and up where there was fewer IMS problems? and are automatics less prone and why?
Old 11-19-2013, 08:08 PM
No IMS 2009 and beyond.
2005.5-2008 large single bearing less failure prone but much more expensive to replace
2000-2004 single row most prone to failure
1997-1999 dual row least prone to failure
Who knows what your current engine has in it though it is probably a dual. But things that rub against things wear out. All of them. Eventually. Some sooner, some later. And while the IMS bearing wears, so do other things inside the engine.
Actually, auto-trans cars are thought to fail more frequently than stick shift cars because of the way they are driven and maintained. No scientific proof of that that I know of.
So you have a choice of replacing the IMS bearing, rebuilding the engine, getting a newer car, getting a new car, etc.
I'll let you use the search term to see previous threads on the merits of various IMS replacement approaches. No need to rehash those arguments again here.
Old 11-20-2013, 06:00 AM
NYC
That's interesting I thought I had read in a few articles that the automatics are less prone to IMS failure.
Old 11-20-2013, 07:25 PM
JFP in PA's Avatar
Only to the extent that there were fewer Tips and manual cars. The Tips can have an IMS failure just like the manual cars.
Accrochez-vous bien de vos rêves..........."
Old 11-21-2013, 03:45 AM
Mine has the auto, with 69,000. going to have mine done. Bad part 3 hr drive to garage. For the LN update , and new rear main seal, 1600.00 including parts. Thought that was a fair price. Mine is a 03 Base. Will just feel better about it.
Old 11-21-2013, 07:38 PM
just read a bit of i info on the flat6innovations, website. in regaurds to the oil fed solution, wich interestingly, does not apply to my 97. but there was some interesting info on failure rates. the education contiues.
Old 11-22-2013, 09:23 AM
for 6.5 inch speakers that fit without making mods: http://forums.pelicanparts.com/boxster-cayman-forum/786514-6-5-inch-door-speakers-fit-without-mods.html#post7800672
Old 12-11-2013, 08:33 AM
I have a 2000S with 105,000 on it. I'll admit I'm nervous, but not to the point of having the ism replaced. I have the auto, not sure how much the upgrade would cost. But I can't see spending a couple of thousand dollars on a car that's only worth maybe 10.
If the motor goes what do rollers sell for?
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 12-15-2013, 07:00 AM
recycled sixtie's Avatar
I echo your sentiments exactly dm. Have only 40k miles on it. Runs like a top. Have IMS Guardian installed. These cars are cheap to buy but engines are expensive to buy and have prof. installed. A roller would be worth about $3k. After 2.5 years of ownership I don't worry about the IMS anymore.
Old 12-15-2013, 07:18 AM
