Headed home last night, Quinn rolled over 100,000!
Looking forward to a lot more miles behind the wheel. ![]() ![]() And my brake pads sensor light came on! Has anyone used the Cool Carbon pads without replacing the rotors at the same time? I'm most a street-use person but those caught my attention. Thoughts?
2001 Boxster 'S' : even my motorcycle was a 'Porsche', '03 Harley V-Rod 1997 Boxster Base; my (former) DD, now resting in peace 1998 BMW 323iC; my son's DD.....now sold 1985 (early) 944; gone now, but not forgotten 1974 Fiat X-1/9; my first mid-engine car |
Inquisitive user
Uny, Welcome to the club buddy. I know you know all I went through with mine. But all is good now and almost at 107,000 miles. Keep on trucking brother!!
Randy
Perpetual change. It will happen!!! |
100k
You failed to mention if you're on the original IMS!
I gots to know!
My personal theory is that the most susceptible engines are the ones that get used 4 times over two months then sit for the other ten months (or some such). My car gets driven 3-5 days per week from March to December & at least once a month even in the heart of (Upstate NY) winter. I think the sitting time allows the seal to harden & leak/pass oil, thus accelerating the wear. No science or numbers, just a personal theory! My first Boxster had very few miles on it & it was a prime candidate for a failure (in my theory) but it was totaled & towed before I could verify that. It was part of the reason I bought that car quite cheaply & the low miles were why the replacement check allowed me to move up to a newer 'S'!
I've got the same car, silver, with a little over 79.000 miles on the IMS. I'm driving nervous!
Anyone running the Cool Carbon brake pads?
My 2001 S has 113,000 miles on it. Just replaced the clutch and IMS and water pump. etc... The clutch was original and was close to the rivets on the disc. If you chew up the flywheel it adds considerably to the parts cost. Had a local specialty shop do the work and they are awesome. I live in Madison WI and I used Kelly Moss. Keep racking up the miles as our cars are not worth much so might as well enjoy them. How long are suspensions suppose to last, my car has the 030 suspension code?
2011 Cayenne S 2001 Boxster S |
I used Cool Carbon pads on my Honda race car. The pads were bonded and I had one come off. You should replace the rotors when you install new pads, better stopping and life. Tell Price at Kelly Moss Hi for me
Paper Member
My '97 has close to 204,000 miles and the original IMS and water pump also. I just replaced the original a/c compressor this summer. Enjoy
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
My 05 Base has joined the 100K club (100878) and counting. I took it in for an RMS and IMS replacement. The shop showed me that my car had the "Final Solution" IMS which would mean they'd have to open the engine to replace. I already have the magnetic drain plug and check the filters, so I just changed the clutch and RMS. I enjoy it immensely! Looking forward to rolling over another 100k.
Stranger on the Internet
Congrats!
149k. I just changed out the original shocks to RoW M030. Front caliper rebuild next; inner pistons a bit sticky.
Patrick E. Keefe 78 SC |
I just joined the 95K club. At this rate, I'll be at 100K in April of '14. Still uses no oil at all between changes.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I used cool carbon pads on my 930 and they were terrible on the street- squeaked a lot and had poor bite until warmed up. They were great on the track though.
