Boxster S Turn Signals
Decided to upgrade to LED on my 02 Boxster S with HID lights. Wondering if there dis circuit overload. Lost turn signals & repeatedly blowing Hazard fuse. went from 15 amp to 25 fuse to stop it but no joy on turn signals front or rear. Hazards do work though. I replaced side markers, front parking lights & license plate with LED, & front fog lights with halogen hyper white. Think its overload? or relay?
Old 01-13-2014, 04:26 AM
Well, what are the wattages of the bulbs you pulled out, and what are the wattages of the bulbs you put in? Going from incandescents to LEDs, you should consume way less power. Blowing a 15A fuse is not a good thing (and changing it to a 25A is just going to help you to fry your wiring harness).
I would start by putting everything back to stock. Replace one bult at a time until you find the one which causes the problem - likely as not, you have a defective LED on your hands and it is presenting as a direct short. If you can run the LEDs on the bench, all the better (at least it will be quicker).
Tom Coradeschi
03 Boxster
Old 01-13-2014, 09:46 PM
Thanks Tom, appreciate the help
Old 01-14-2014, 06:50 PM
Were you able to get anywhere on this problem? Enquiring Minds want to know...
Tom Coradeschi
03 Boxster
Old 01-17-2014, 08:16 PM
There's also a load equalizer that you can buy at any parts store that might help with the situation
Old 01-22-2014, 12:52 AM
