Bad cat help '03 S
Hi Crew,
I got a check engine light on my '03 S. An evaluation with my Durametric tool showed P0430 Porsche fault code 45 - Cat conv efficiency bank 2. When I looked at bank 2 pre and post O2 sensor voltage, they are both making similar wave length oscillations. Based on what I have seen, this means that the cat is toast. I am in an area where smog testing is not done. So I could replace the cats with test pipes, but how would I keep the check engine line from coming on?
Any feedback would be appreciated.
Thanks!!!
Old 03-23-2015, 08:51 AM
OBD can be a funny thing.
Sometimes, for example, a bad MAF Sensor can cause codes associated with "downstream" components.
It's seldom 100% that the code accurately describes the problem with respect to emissions components.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 03-23-2015, 09:14 AM
Paul V
paulv's Avatar
Originally Posted by C_Adams View Post
Hi Crew,
Thanks!!!
Before I would decide that the cat has failed, I would do something easy that doesn't cost $ by swapping the post O2 sensors between banks and see if the problem follows to bank 1 (P0420), then you would know know that the post O2 sensor needs to be replaced.
BTW, the factory diagnostics mention the possible fault causes, in this order, to be:
1) The pre- and post- O2 sensors were exchanged
2) valve lift fault
3) aged post O2 sensor
4) cat failure
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 03-31-2015, 04:47 AM
Burn the fire.
Brando's Avatar
If you are going to remove the CATs and don't want a CEL, you have a couple options:
1. Flash the ECU ($800-$1200). Has the added benefit of some added power.
2. Install a couple of "Mini Cat" spacers: Link
I did #2 when installing my sport-cats because the measurement was very strict on my stock Cayman S. ECU Flash comes later with some other goodies.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-31-2015, 12:19 PM
