aaron (guest)
Guest
Posts: n/a
My 2006 boxster is at a auto electricions at the moment, my passenger window doesnt always go back up again when the the door is closed, i also get a flat battery every time i leave the car standing for more than 24 hours, they seem to think its the window module causing this based on previous similar VW issues, does that sound right to you?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-07-2016, 08:12 AM
Nick at Pelican Parts's Avatar
The issue may be in the door latch switch. If the door isn't seen shut, the window will bot close.
- Nick
