Guest
Posts: n/a
sorry to bother you again wayne but still cant find the bleed cap for the coolent to fill more coolant. I have taken of the filler caps oil n water and removed the cover but it just shows the metal bulk head not any bleed valve they are on the side not like your photo. Help were is it cant fill the coolant without bleeding system. 07 boster 2.7 engine thanks Tony
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Coolant Replacement / Boxster Coolant Flush - 986 / 987 |
Author of "101 Projects"
What you have here is a 987-2 style tank, which is used on the Cayman and 2007 and later 987 cars. There is no bleed plug on this one, you need to pull a vacuum on the system in order to bleed it. I probably need to do a tech article on this sometime in the very near future.
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I would LOVE to see a how-to-do article on coolent flush/fill for the Boxster 987.2!!!!!!!!!!!
That is the next thing I would like to to on my car. Chris Austin, Tx 2010 Boxster |
