Louis (guest)
Guest
Posts: n/a
I have a 1999 986 and the key will not lock the door. I have not used the remote key because it is broken. Will a new remote key enable me to lock the door or do I need a new lock
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 11-04-2016, 09:56 AM
Nick at Pelican Parts's Avatar
I would assume you need a new lock or latch if the mechanical key isn't working.
- Nick
stormcrow's Avatar
Louis,
If the key turns in the cylinder then the shaft going from the key cilinder to the lock mechanism is disconnected. Neither of my doors would lock and after i investigated by taking the door panel off i found out the horizontal shaft on the driver side was out of the slot.
On the passenger side the shaft wsa in the door locking slot but a tiny pin fell out where the horizontal shaft attaches to the door handle.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 11-04-2016, 04:53 PM
