Question on A/C Overhaul
Historically, I have had a slow freon leak in my system, which I believe was traced to a leak high pressure port valve in part. So earlier this summer, I decided to recharge. Unfortunately, during the process, I had a fairly violent high pressure side hose breakage during a/c pressure gauge hookup and lost a major portion of the freon. I never lost all the freon and the system still had charge in it, so I did not reclaim the balance and vacuum. I simply recharged the system but it is not performing properly.
If I recall correctly, the high pressure side is not quite high enough and the low pressure side is on the higher side of the range, so I suspect the compressor is going. I am inclined just to overhaul the system and my questions are as follows. With such a violent high pressure side loss, how much oil is lost in the process and how to determine it? If I were to going to swap out the compressor and put new port valve on, likely on both side, as long as I have the system open, what else should I go ahead and change before sealing it up again and how much oil to add? Any comments, pointers etc appreciated.. |
You may be reduced to having to flush the system with a special solvent to remove all remaining oil, and then start over from scratch with a full oil charge. Good luck with this one.....
Accrochez-vous bien de vos rêves..........." |
just to close this out, I have another post on the same subject..see those comments
