Go Back   Pelican Parts Forums > Regional Forums > Canada
billroth's Avatar
Lift source in Canada
I was trolling, looking to see if I could find a Bend Pak lift in Canada and look what i found!
http://www.canbuilt.com/catalogue_pdf/VL-MRL648.pdf
I wonder how much they are?
Lawrence
1985 911 Coupe Black
1985 911 Cab GP White (killed)
Old 10-06-2006, 11:27 PM
Eldorado's Avatar
regular price is $2995... current sale price is $2795..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-07-2006, 03:16 PM
billroth's Avatar
Thumbs down
A bit steep compared with 899 USD at Harbour Freight.
Old 10-07-2006, 07:27 PM
Send a message via AIM to hpaulb
Doesn't look like it would be very handy unless your working on the brakes. How do you work under the car?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 10-10-2006, 06:35 AM
Counterclockwise?
A group buy at Rennlist has one to my door @ $1500 US.
Rod
1986 Carrera
2001 996TT
Old 10-12-2006, 06:26 AM
billroth's Avatar
Is that BendPak or HF? Are they the same?
Also, how are you going to get the thing out of the truck? 1000lbs!!
Lawrence
Old 10-12-2006, 09:54 AM
Counterclockwise?
gregsmithequipment.com
1,000 lbs isn't that much.
Link
http://www.gregsmithequipment.com/product_p/tppro-6m.htm
Rod
1986 Carrera
2001 996TT
Old 10-12-2006, 10:26 AM
Nape75'911T's Avatar
Lawrence......I can get this lift for
$2400.00 delivered and set up.....likely a little cheaper if more than one person is interested........you still interested??
Mark
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 11-30-2006, 06:13 AM
I bought one of these a while ago:
http://www.hydra-lift.com/lowrise_16&17.html
It looks like this in use:
As I recall it was about $2500 delivered to my door.
Nice guy - he got it off his trailer in my driveway, then we used the roll-around feature of the lift to get it into the garage.
If you are on the fence - get one - i use it a lot, way more than I thought when I bought it.
I did a bunch of research, and decide on this one because with a couple of little mods, it has a low enough profile that I can park over it without setting it into the floor of using planks (well, at least until my last suspension tweak - I now am about 1/2" too low).
I have rolled it out into the driveway and used it there (much to the consternation of my neighbours).
This type is great for 911 because you really don't need access to the middle for anything. Access to the front and rear is perfect, and it made getting the engine in and out a breeze. Well, maybe not a breeze, but pretty easy.
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff
'74 Fiat X1/9
2021 X5
Old 11-30-2006, 06:00 PM
I looked at the Hydra lifts too.....
they are really nice. Basically the same idea and price point, I just wanted the ability to lift a little higher.....I believe the other lift will raise to over 40".
I am still on the fence too.....but I know I will use it a lot......if I had it right now, I could be knee deep into a couple of projects I am planning !!!!!
Thanks for the post and the comparison.
Old 12-01-2006, 07:22 AM
