Guest
Posts: n/a
05 Mini Cooper S Car was sitting for a year and a half. Car would not move after new battery was installed. Would changing the transmission fluid solve this problem? Low energy light comes on inside the car.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The vehicle starts and run, but does not drive? Did it drive before it was left to sit?
I would start by checking the transmsiison fluid level. - Nick |
I worked on one that sat foe just over a year . ..
It took moving to drive , N , P , R a few times then she started gripping. The transmissions are "sealed" but fluid can be changed (it is an interesting system that you need to do (I have a container and hang it from the rafters and use gravity / trans pump to do the work .)
Brian Enjoy Life ... Eat out more often ! |
