Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
m04081 (guest)
Guest
Posts: n/a
My 03 mini s 6 speed manual trsnny started slipping at high rpms. What could cause this. Also the cat which is built into the end if the exhaust header is leaking and loud. Meinike quoted $1000.00 just for exhaust assembly. Any known patches?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change
Old 01-22-2016, 06:56 AM
Nick at Pelican Parts's Avatar
You can't patch exhaust.
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
Couldn't this be the Clutch slipping on the flywheel? it sounds like what mine is doing in my 05 Cooper S also.
Old 02-11-2016, 10:58 AM
2007 Mini Cooper
I agree with brazharris on it being the clutch. I replaced mine 3yrs ago in my 07 mini with about 110,00 miles...mainly highway miles.
Old 02-13-2016, 07:50 PM
