Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
matt (guest)
Guest
Posts: n/a
How difficult is it to change the front brake caliper rubber dust boot? Do you need to take the caliper apart?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Front Brake Pad Replacement
Old 04-01-2016, 01:51 PM
Nick at Pelican Parts's Avatar
You need to remove the piston. We use to replace them on vehicle a long time ago. Remove the caliper, then use low pressure air into the caliper hose fitting to push the piston out. Replace the O-rings too.
- Nick
