Writer/Teacher
Porsche flat-six engine 1/4 scale model kit — noisy motor?
So, I got my flat six model kit together and it’s working as expected, but the motor is significantly louder than I expected, with a strained “whining” noise. Does this mean that I have something too tight in the drivetrain?
Those of you who have put this model together: does yours sound like this? (Note: I’ve removed the fan housing and some other bits to get a better look at what might be going on) https://www.youtube.com/watch?v=oa8JsDYVTCs&feature=youtu.be Last edited by CJFusco; 12-28-2018 at 06:55 PM.. |
Sounds like the timing chain tensioners. Honestly, I have no idea.
Spray some silicone into the cylinders. When I was a kid, I think some kids put the ''Visible V8'' together with vaseline as a lube. They never worked well, and they always sounded thrashy. |
Slackerous Maximus
That does not sound unusually loud for a plastic model being driven by an electric motor.
2022 Royal Enfield Interceptor. 2012 Harley Davidson Road King 2014 Triumph Bonneville T100. 2014 Cayman S, PDK. Mercedes E350 family truckster. |
cycling has-been
Be interested what the compression and leak down figures are??
Sounds like one crank journal is too tight. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Control Group
Valve adjustment
She was the kindest person I ever met |
Carbon on the valves...
No, wait, that's on Ferraris. |
a.k.a. G-man
SSI and an M&K exhaust.
Made my car sound awesome... ![]()
Сидеть, ложь, Переворачиваться |
My model makes the exhaust sounds of throttle blips much louder than the mechanical sound of the electric motor drive. Although I find it typical for a plastic geared model with no lubrication to be a bit noisy. Maybe a dab of Vaseline on the gears and bearing journals would help? Since this model required no glue, maybe you could take it apart and make sure the gears are installed in the correct orientation. And there is no binding with the main, rod, cam journals and the valves move freely in the guides.
Gon fix it with me hammer
muffler bearings are out of allignment
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Time for a full tear down, polish, balance, and blueprint.
Recreational Mechanic
Must have a bad IMS.
Sent from my Galaxy S9 using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
I don't get it. Why are 7 out of 10 replies idiotic replies? Someone goes to the forum to ask for some help on a plastic 911 engine model and he gets stupid replies. Come on people, we aren't like that when someone asks for help on a real engine. Give the OP a break.
Writer/Teacher
Thank you for the (sincere) replies. I mean, the engine is functioning correctly — all the cylinders are rotating, the valves are opening and closing, the spark plugs are firing in the correct order etc — it’s just a little noisy. Since it took several hours to build, I’m not about to disassemble and rebuild again right now... but maybe it’s something I’ll do down the line.
I dunno, my full scale one with megaphones is loud as hell! Sorry, I couldn't resist!
Patrick |
Behind the Sun
Dump it
Put a 3.8 Never look back |
Put some Slick 50 silicone lube in it.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Serious questions will get serious answers. A toy engine made of plastic and an near infinite reason to sound "funny" will get attempts at humor for replies. Some are funny, some are not so funny, but it is all in fun. No one really cares why his toy does not sound like he though it might. It is a plastic TOY or model of a real engine. Humor or wise cracks and funny replies are the norm to not serious topics, and often to very serious topics as well. There are no real rules, except to not use profanity or pornography.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Carrying on with the unhelpful theme, does this model make any provision for lubrication? Suppose you drilled teeny weeny holes and ran oil lines fed from the sump via a $10 pump? Might need to use teeny weeny beads of silicone sealant and Tri-X lube.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I built the same with my kid. Mine is not quite as loud but neither is it super silent. I think as you suspect that you are hearing the electric motor a bit more than I am, because it is straining to rotate the thing (something a little tight in there)... I don't think I've run mine again since it was built - fun time though.
Thread Tools | |
Rate This Thread | |
