Unregistered
sammyg2's Avatar
Originally Posted by Instrument 41 View Post
Any advice on how to strip this wire back to attach a new light fixture. This is for a wall sconce and the original thought was to get rid of the fixture. However....after the project she decided to keep it. There isn't any slack in that wire to pull it out any more. Any suggestions??
Move the light fixture down about 6 inches?
Old 02-14-2019, 07:27 AM
least common denominator
scottmandue's Avatar
Beat me to it!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-14-2019, 07:38 AM
Platinum Member
dad911's Avatar
1) Fire whoever cut the wire. No reason for it. Never bury wires, even if unused. Should have wire nutted leads, and put a blank plate on it.
2) proper repair would be to (a) cut back sheetrock and find some slack. (b) move box to make slack. (c) If you can possibly strip leads, a push in connector would need less slack than a wire nut.
Old 02-14-2019, 07:39 AM
Brew Master
cabmandone's Avatar
Originally Posted by Por_sha911 View Post
Cut the sheetrock, put in a junction box, splice in a longer wire, patch the sheetrock.
Most electrical code prohibits a junction box inside a wall.
I'd see if you can find the source for the wire and pull a new one. If you home is on a basement and the wire on an inside wall with a source through a switch, it wouldn't be hard to replace the wire.
Why is that so? Enquiring mind query.
I think it has something to do with a wire nut causing heat and the fact that if the wire nut came loose, it wouldn't be serviceable and could short out causing a fire.
Nick
Old 02-14-2019, 07:54 AM
Platinum Member
dad911's Avatar
I would remove that box, a hacksaw blade between the box and wood, and cut the nails.
Then strip the wire, use an 'old work box' and push-in connectors to add new tails.
Easy-peasy, 30 minute (1 beer) job, less than $10.
With the box out, I also suspect a 'gentle yet persuasive' pull on the wire will find another inch or so.
Old 02-14-2019, 08:09 AM
Brew Master
cabmandone's Avatar
^^^ That!
Most electricians will leave a little extra. If you give the wire a gentle tug you might get a bit more to work with.... unless the electrician used a wire staple on the stud the box is mounted to... Then you're shafted. A pair of needle nose pliars should tell the story pretty quickly without removing the box.
Nick
Old 02-14-2019, 08:23 AM
A box in the wall is permitted with an access cover. Is there a hutch or cabinet below that could hide a box?
The new box could also be a switched outlet which then feeds the sconce....
Or a box with a receptacle that is not wired. It's simply a J-box.
Less liked solution:
Cage clamp butt splice.
Wago and others make them.
Old 02-14-2019, 09:11 AM
The staple should not clamp the wire...if it's done right it will pull through. If it's done wrong it won't.
Old 02-14-2019, 09:14 AM
Thanks guys for all the info. There isn;t any slack in that wire. If there was then I would not be dealing with this issue. I'm gonna tackle this in the morning.
Old 02-14-2019, 03:47 PM
Maybe cut the hole in the box( if it's plastic)
that the wire is run through to beable to pull the wire a little more forward.
Get a cheap extendable utility knike and cut the sheathing from the romex.. at that point you should beable to add pig tails.
Or...pull that box completely out..should be held on with only 1 or 2 nails, do what you have to with the wires and replace the box with a remodel type.
It's easy to install, just 2 wings the pull to the back side of the sheetrock..
Old 02-14-2019, 04:36 PM
Information Overloader
Don’t cut the wire!
My experience with such matters is that no matter how many times I cut something, a board, a wire, a finger it’s still too short.
Old 02-14-2019, 04:56 PM
Cover it up. She had her chance.
JUAN
'80SC Targa
Old 02-15-2019, 04:55 AM
OK guys, finished this project. Cut out the bottom of the box and it gave just enough in the wire to get to it and strip it. Tha'ts 156 on a list of about 700, down and out.
Old 02-15-2019, 02:08 PM
Good job!!! It was probably easier than you were anticipating it being..
Old 02-15-2019, 03:13 PM
crustychief's Avatar
https://www.amazon.com/ALUM-COPPR-3PORT10PK-KING-MfrPartNo-95110/dp/B00IA87S0Y?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-ffnt-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00IA87S0Y
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-15-2019, 04:36 PM
