Splice a fuel line? squirrel damage
Probably a dumb question, but here goes.
I have a pinhole leak in a fuel line, probably due to a squirrel biting it. Has anyone ever used a fuel rated hose coupler to repair a fuel line?
Replacing the whole line requires dropping the gas tank. Just wondering if that ever done, or if I have to bite the bullet.
Thanks!
Neil
'73 911S targa
Old 05-22-2019, 08:05 AM
biosurfer1's Avatar
possible? Sure, but gas and brakes are two parts of the car I never go cheap on. Catching fire or not stopping at highway speed don't sound fun.
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 05-22-2019, 08:09 AM
Rick Lee's Avatar
I always thought the problem with fuel lines was accessing the end points to R&R the whole thing. I had one in my '87 Carrera that required a lot of disassembly to R&R. The photos the shop took were frightening and the labor was many times the cost of the part. So, if I could have patched it, I would have.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-22-2019, 08:23 AM
fastfredracing's Avatar
Do it all the time. What kind of material are you working with ? There is a repair for nearly every type of fuel line out there.
Obviously, access is usually the hard part .
No left turn un stoned
Old 05-22-2019, 08:28 AM
VincentVega's Avatar
What kind of car? Low pressure carbureted cars have lots of rubber hose and clamps. Simple enough to splice in a patch. Use spring clamps. Higher pressure fuel injection? Not so sure. Sure its not rusted or rubbing on something? You could cut out a section and splice in a new metal section but you'd need enough room for a tool to get new ends on the line. How much room do you have?
Old 05-22-2019, 08:31 AM
Control Group
Tobra's Avatar
Fuel injection use fuel injection rated rubber lines. Internal reinforcement, not the sketchy, cloth wrapped stuff.
Old 05-22-2019, 08:54 AM
The Unsettler
stomachmonkey's Avatar
If it's a steel line just weld it back up.
"I want my two dollars"
"Brandon Won"
Old 05-22-2019, 08:58 AM
Shaun @ Tru6's Avatar
I would remove line and bring it to a hydraulic shop for a proper crimped replacement of the entire line with some new Cohline.
Tru6 Restoration & Design
Old 05-22-2019, 08:59 AM
Thanks for the answer. I was looking for professional feedback. It’s some kind of plastic.
Old 05-22-2019, 09:05 AM
They have repair kits for plastic line . There are reinforced unions you can use, and or a tool to push barbed splice fittings into the plastic and the correct clamps
They are a little pricey , and a little bit of a pia to work with, but I do it all the time
Old 05-22-2019, 09:10 AM
^I've used one too, wasnt sure about it but it didnt leak
Old 05-22-2019, 09:51 AM
fred cook's Avatar
Replace the part and get on with your life! Not worth worrying over!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-22-2019, 10:30 AM
Just some JB Weld and duct tape will do it.
It certainly depends on the fuel line pressure and location. On my 911 the line from the fuel pump started to leak. The only safe true fix is replacement. That line goes from the pump up over the steering rack, down the tunnel, and exist near the nose of the transmission. Working with no room at all is no fun. That line is under high pressure and I was not going to patch it.
Old 05-22-2019, 10:57 AM
BoxsterGT's Avatar
Porsche Crest
Neilk -
If you email me w photos I can advise you.
I make up Porsche replacement fuel lines almost every day and this is something you do not want to play around with.
That said, I do have couplers specifically for the Polyamide lines in a 911 if that is what you are asking about.
email me at: Len.Cummings at verizon.net
Old 07-30-2019, 01:09 PM
Arizona_928's Avatar
LOL
dolor et pavor
Copyright
Old 07-30-2019, 01:57 PM
Originally Posted by BoxsterGT View Post
Neilk -
Thanks for the offer. I brought my BMW to a local shop and they used a coupler to fix the line around the leak. No more gas smells, so holding tight.
Neil
'73 911S targa
Old 07-30-2019, 02:27 PM
BoxsterGT's Avatar
Porsche Crest
Good thing you brought it there.
Don't do BMW's. Only Porsches.
Len
Old 07-30-2019, 02:58 PM
Still here
pmax's Avatar
BMW w/edible fuel lines ... figures.
What's next ? Organic impellers ? Wait ...
Old 07-30-2019, 05:57 PM
wdfifteen's Avatar
Squirrels chew through a steel fuel line?
Oh. Yeah. Texas squirrels.
Old 07-30-2019, 06:22 PM
Had this car in a few years ago.
http://forums.pelicanparts.com/off-topic-discussions/933809-what-eating-honda-accord.html?highlight=eating+gas+tank
Old 07-30-2019, 06:33 PM
