Control Group
Tobra's Avatar
Milt, do you pull/push the edges together or just hit them with the superglue?
It is possible to take two small pieces of tape, attach one on either side of the cracked area and pull the edges together. This is particularly effective if you use some sort of skin adherent, such as tincture of benzoin or some other skin prep. Sticky part of a bandaid cut into strips works well as a make shift "butterfly"
Old 01-01-2020, 03:42 PM
Originally Posted by Zeke View Post
Works for me. On heels and fingertips just under the nail. Sanding down helps a lot too. With both, they don't crack open again and again. They heal instead.
another vote FOR superglue here, when the tip of fingers beside nail has split I've been glueing the edges together which holds it for a couple of days while it heals,
(usually caused by working in the rain which I understand is due to an amount of acid in rain drops, as opposed treated water in tub which has been processed to remove it as I understand)
Nineteen Ninety One 964
Old 01-02-2020, 06:18 AM
Tobra; I push the edges of split together (if possible without sticking both those finger to split at same time)
but as long it forms a blob/bubble inside and above split it appears to have worked OK so far at least.
OUR A&E dept use a 'sterile' version apparently instead of stitches on some wounds
Old 01-02-2020, 06:29 AM
See also:
https://forums.pelicanparts.com/off-topic-discussions/1146061-moisturizer.html
Old 09-10-2023, 10:04 AM
Jeff Hail's Avatar
Made from sheep pimples (fat lipids and oils secreted by the sebaceous glands) and 8-Hydroxyquinoline, wax. Mild fungistatic, bacteriostatic, anthelmintic, and amebicidal action. Good for the mitts and the vulva. Traps that moisture and locks it in.
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 09-11-2023, 12:01 AM
