-   -   Gas Pressure Washers Suck regardless of brand (http://forums.pelicanparts.com/showthread.php?t=1056847)
cabmandone 04-03-2020 04:59 PM
As others have said, non ethanol fuel is a key. For the pump they make a pump cleaner/lubricant that you're supposed to use. Having said that, I have a 4000 psi unit with hot water that I've had for almost 12 years that never gives me any issues.
wdfifteen 04-03-2020 05:00 PM
Originally Posted by No Sweat (Post 10809862)
1 Don't run anything other than water through the pump !!!
2 Always get any air out of the hose/pump before starting !!
3 Don't let it run in bypass for more than a minute !!
4 Chemicals will eat the pump o'rings and the hose o'rings !!
5 Always use stabilizer with Ethanol gas or find Ethanol free gas !!
That's a start for now, :) Mine is 20 years old and still GREAT.
I do all that and my Troy-Bilt is still working great after 10 years.
Bill Douglas 04-03-2020 06:08 PM
Darn. I was going to buy one with a Honder engine. I always think if it's got a Honda engine it must be excellent.
I DON'T like electric ones. I always think I'm going to get electricuted. All that water and electricity....
mepstein 04-03-2020 06:49 PM
The subaru that I got at Costco a couple years ago always works fine.
Hendog 04-03-2020 06:56 PM
Yes sir! That's how it's done. That, and a Honda engine on a Karcher pump. Going on 16 years.SmileWavy
red-beard 04-03-2020 07:14 PM
The Craftsman I had worked fantastic for YEARS. Then E10 killed it.
Baz 04-03-2020 07:38 PM
I have a gas (Honda) Karcher and an electric (Sun Joe) but was at a client's property today and he was up on a ladder washing his metal roof panels using one of these.....$99 at HD......
Ryobi 1,600 PSI 1.2 GPM Electric Pressure Washer
https://images.homedepot-static.com/...12-64_1000.jpg
RSBob 04-03-2020 09:11 PM
Have had a $500 HF pressure washer which has run flawlessly for the last 5 years. The great thing about HF is they have this crazy warranty you can buy for cheap, where if you bring the unit back, running or not within the year you bought it, they give you a replacement no questions asked. Get the replacement and pay another $15 for another warranty, and then repeat year after year.
Rusty Heap 04-04-2020 08:17 PM
Originally Posted by Rusty Heap (Post 10809884)
This may be the unit..............good old HF.
$899
I found a $100 off coupon, for $799.
4000 psi with a vario pressure reg on the wand.
https://www.harborfreight.com/4400-psi-42-gpm-13-hp-420cc-commercial-duty-pressure-washer-epa-64931.html
THIS THING IS A BEAST, both in physical size and power strength. must be 3' x 3' x 24" wide. Great tube frame work design, good ergo rolling it. Wand is heavier duty. Makes my other 2500-3000 psi units look like hobby toys.
They list it as 4400 psi, 4.2 gpm, and a 420cc engine (started on 2nd pull, and was little pull strength needed)
nice, $799 and a 2 year $150 no questions asked return policy and they give you a new one. It's a hellll of a lot of machine. :eek:SmileWavy
https://shop.harborfreight.com/media...4/64931_W3.jpg
RSBob 04-04-2020 08:23 PM
That is pretty much the one I have. Amazing how long it runs on a tank. The price has gone up in 5 years. You will like it.
rusnak 04-04-2020 09:08 PM
http://forums.pelicanparts.com/uploa...1586059499.jpg
Simpson Water Blaster - cold water pressure washer with Honda GX 390 motor. It's been totally reliable, and we use the hell out of it. Typically for 4-6 hours at a stretch. The pump uses 30-wt non detergent oil. You have to change it probably once per year or so. Typical wet sump engine lubrication using 10-30wt oil.
dan79brooklyn 04-04-2020 10:54 PM
I have an electric Stihl that I bought used for $50 retails for several hundreds. Works great!
john70t 04-05-2020 08:30 AM
Originally Posted by stevej37 (Post 10809967)
I learned quickly to shut the water off and release the pressure when starting.
I got hold of a 'trashed' pw that would not start unless the handle was on.
But once it got started and warmed up, it was a beast.
I try to keep the water flowing while it's running. Cycling the on/off all the time probably does damage to the internals and pump.
1990C4S 04-05-2020 01:08 PM
I have a 200 cc 3,000 psi 'Mack', which appears to be just a Chinese high volume cheap washer.
Today I had to re-seal the case (major oil leak over the winter), acid wash the fuel tank (the gas cap is not rain tight so my 'fuel' was 90% water). From the water/rust the fuel shut-off valve was clogged, so that had to be drilled out.
By the end of the day I got it to fire on quick-start.
Tomorrow I can reassemble, and then hope the carb and pump work....
If I wasn't quarantined I would question my sanity, but I don't have much else to do right now. :rolleyes:
dan79brooklyn 04-05-2020 04:17 PM
My used Still has this exact problem. If I release the handle in the model of a spray job it won't start up again. So I have to plan my cleaning jobs carefully ;)
rusnak 04-05-2020 04:33 PM
Maybe your pump bypass is stuck closed.
<iframe width="560" height="315" src="https://www.youtube.com/embed/3PxPngJfmM0" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Embraer 04-05-2020 08:35 PM
I just changed the oil on my Generac Pressure washer today, and did some cleaning. Works great. The main thing, I always disconnect the hoses when I'm done, and pull the starter a few times to clear the water out of the pump. They recommend putting antifreeze into the pump over winter, or if it's going to sit a long time.
SiberianDVM 04-06-2020 06:44 AM
Used my new Karcher yesterday. It was great. Almost blew me off my feet.
flipper35 04-06-2020 12:10 PM
Dad bought a used one, not sure the brand but looks very similar to the Simpson above. The only issue with it is that it doesn't always start on the first pull. We never use anything but E0 in it and put Stabil in at the end of the season.
JeremyD 04-06-2020 12:16 PM
I've tried to kill my Troy built one for years and it still runs strong - Nothing but E0 - (it's probably 10 years old and I use it all the time on boats/dock/porch)
