-   -   Gas Pressure Washers Suck regardless of brand (http://forums.pelicanparts.com/showthread.php?t=1056847)
1990C4S 04-07-2020 02:35 PM
And now my efffing needle is leaking fuel. FML. Two days and it's still not done.
astrochex 10-18-2020 08:13 AM
Can anyone recommend a good hose? This is the hose that came with my Ryobi after not more than 10 uses. TIA.http://forums.pelicanparts.com/uploa...1603034016.jpg
dar636 10-18-2020 09:49 AM
Originally Posted by No Sweat (Post 10809862)
1 Don't run anything other than water through the pump !!!
2 Always get any air out of the hose/pump before starting !!
3 Don't let it run in bypass for more than a minute !!
4 Chemicals will eat the pump o'rings and the hose o'rings !!
5 Always use stabilizer with Ethanol gas or find Ethanol free gas !!
That's a start for now, :) Mine is 20 years old and still GREAT.
+1, 15 years on my Honda powered Home Depot? I forget where I bought it...
look 171 10-18-2020 10:05 AM
We no longer use pump gas instead, we buy those cans of non ethanol fuel from Home Depot or gardening shops on all our small engine equip.
Lexus4321 10-18-2020 10:09 AM
You need to find stainless hardware. All the generic ends are steel and poorly treated (plated). They make them cheaper..... and now you see where too.
Find a local hose/fitting place that can replace those ends with SS ones.
wdfifteen 10-18-2020 03:32 PM
What's the problem? It looks like the O-rings are in good shape. Is it leaking or what?
astrochex 10-18-2020 03:38 PM
It was leaking significantly at the wand end. Low pressure out the nozzle, and free bath at the trigger.
wdfifteen 10-18-2020 03:54 PM
Yeah, that sucks.
Lexus4321 10-18-2020 09:32 PM
1 reason why that happens is sheety design. The entry on the end of that connection should be tapered ("crowned"). Look inside the port they connect into, the water exiting there does not exit a hole same size as the wand connection end, nor does the end of the fitting mate up against anything in the pump exit port !!! So basically water PSI is just slamming into those rusty faces all the time, hence why that rust happens all too fast.
You want it to last, find some stainless fittings from local hose/fitting place, then take them to a local machine shop and have them taper the inlet so that the water PSI has a smoother transition from pump exit into the fitting, etc. Maybe run a 45-60deg taper, run it in leaving about 20-50 thou at the edge (so it's not knife sharp, etc).
Until then, they will be rusty and problematic.
red-beard 10-19-2020 06:08 AM
My Home Depot/Honda pressure washer is still working well, even with ethanol gas. I turn of the fuel valve and let it run out of fuel. I also change the oil every year and a new plug properly gapped.
The pull cord broke. I ended up just using the shorter cord and it still starts fine.
ckelly78z 10-19-2020 08:01 AM
https://www.costco.com/husqvarna-3100-psi--2.5-gpm-gas-pressure-washer.product.100540389.htm
We bought this Husky unit, and love it so far. I have probably 10-15 hours of run time on it throughout this year with no issues. It will be interesting how it behaves in the Spring for the first time running after Winter.
hcoles 01-21-2021 07:55 AM
I'm hoping it is okay to tag on to this thread. I'm looking for an electric PW. I have an old one (15 years?) I got from my Dad years ago. I think he got it from Costco. 1300 psi it says and made in Italy. It works okay for most applications. It is starting to act up. Motor starts going faster while I'm using it. What is the current thinking on best "low" pressure electric washer?
This is what I have.
https://www.blackrockgalleries.com/product/husky-hd-power-washer-1300-112898.html
masraum 01-21-2021 08:23 AM
I'm looking at a Ryobi brushless electric at HD.
https://www.homedepot.com/p/RYOBI-2-300-PSI-1-2-GPM-High-Performance-Electric-Pressure-Washer-RY142300/300405751
I'm curious to see if you get any good responses.
astrochex 01-21-2021 08:45 AM
I just picked up this nugget to replace the prior Ryobi. Its very compact and passed the first use test. I also like the easy access placement of the hose and wand connections. I'm now a big fan of the turbo nozzle.
https://www.homedepot.com/p/RYOBI-2000-PSI-1-2-GPM-Cold-Water-Electric-Pressure-Washer-RY142022VNM/313760964
I think user error broke the other Ryobi. I do not recall consistently running water through the unit before turning the pump on. That will not happen again.
stevej37 01-21-2021 09:18 AM
I got this one from Amazon this summer. Enough pressure for what I use it for...and I really like the feature of that the motor only starts when you pull the wand trigger.
Yeah..the turbo nozzles are great!
https://www.amazon.com/Sun-Joe-SPX3000-BLK-Pressure-14-5-Amp/dp/B073FBKQL1/ref=sr_1_2_sspa?crid=1NFJ7H42VYGVJ&dchild=1&keywor ds=sun+joe+electric+pressure+washer&qid=1611249262 &sprefix=sunjoe+ele%2Caps%2C186&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExR1pWQ kU3SkxUM1MwJmVuY3J5cHRlZElkPUEwODM3NzIzMzhVVjhYUTd PS01DNyZlbmNyeXB0ZWRBZElkPUEwODEzMjgxR0tQRDdNRVBPT 1dYJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGl yZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
hcoles 01-21-2021 09:55 AM
Thanks for the responses. I saw a review mentioning that the motor shuts off when the trigger is released. Good, that's what I have now and I feel it is a must have feature.
hcoles 01-21-2021 10:25 AM
I'm a bit confused regarding the model numbers and what they look like.
On the HD website the model number is 141920 (1900 psi) but this doesn't seem to match anything on the Ryobi website. On the Ryobi site I see a model 142022 (2000 psi). I guess the models are changing as time passes, maybe HD is selling the "old" model.
masraum 01-21-2021 10:36 AM
Or maybe Ryobi makes models specific to HD to meet price points?
Groesbeck Hurricane 01-21-2021 10:47 AM
I bought an electric generic type greenworks one from lowes a couple of years ago. I have run it for hours at a time cleaning out the cattle trailer without issue, well, it uses up the soap dispenser faster than I want it to. No rust on the connections AND it was cheap, on sale at the time.
FIL went through four or five powered ones, none ever lasted more than a year or so. We gifted them an electric one last year. Complained it was not powerful enough before they ever used it. Never heard a complaint after they used it.
Too much PSI can take the paint off your car/trailer/house/concrete.
Nickshu 01-21-2021 10:49 AM
I agree...I ditched my gas pressure washer for a Karcher electric and will never go back . I'd rather buy a generator to run it than another gas pressure washer.
