Home of the Whopper
Repair a cracked engine block?
Pulled the engine out of the old sea ray to freshen it up, and found this:
![]() That's one heck of a freeze plug. Maybe its welded in! So now what? Replacement engine? It is a mercruiser 165hp inline 6. I see them online, but is there a better replacement engine?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
If the block is no longer available or super-expensive you could gouge the cracks out and nickel weld them with a stick welder. That's what I would do.
Or JB Weld it and cross your fingers. If you can get a new block then you should go that route, assuming you want longevity.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Drill the end of the crack as well...
dolor et pavor Copyright |
I am not a welder but a million years ago, I sold welding supplies.
My recollection with the nickel weld rod is that before and after welding, you need to heat soak it. Meaning, run it up super hot, weld, heat again, leave in a thermal blanket of some kind. Don't take my word. Do the research. This type of welding has is super prone to failure. Me? I would junk it. |
Look into metal stitching. Back when I was a wee lad in the UK working as an apprentice in a heavy engineering shop we would stitch across cracked castings. Seemed to work back then and I have heard its quite common practice when a replacement block is tough to source.
'72 Norton Commando, '47 Sunbeam S7 '14 Tacoma |
I had the same issue with a volvo penta. I drilled each end of the crack (not all the way through) and then gouged the crack. I used a product called Marine Tex. It's been on there for years and never leaks.
My logic was I was never gonna run it out of water and as long as it didn't fill the bilge and sink me I would be fine.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Still Doin Time
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Also, knock the plug out and see how they look from the side.
Yes it can be welded, as already mentioned carve groove and need to preheat the crap out of it and keep it hot. There is a possibility you could also braze that, also requires lots of preheat. Possibly need to gently stress relieve the weld after.
Did you have water freeze in the block? When much younger I welded up a cracked cast iron punch press with Nickel rod, held up with much higher loads than your block will see.
87 930, Last edited by 908/930; 07-23-2020 at 12:32 PM.. |
MAGA
I have successfully and unsuccessfully brazed cracked castings before. If it was mine and had been running that way without leaking, I might just pretend I never saw it.
![]() ![]() If attempting to weld, if you can't preheat and then slow cool, you have a good chance of hearing a loud crack some minutes after welding.... BTDT
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. Last edited by Tim Hancock; 07-23-2020 at 12:39 PM.. |
Home of the Whopper
I am guessing at some point in its 50 year life, somebody didnt properly winterize it.
If its cracked there, it may have other cracks too. The oil was always a little milky, I just changed it frequently. The chevy 250 inline six is apparently the same engine but not marine grade. Rebuilt for around $1500, then swap over some parts to make it marine grade. Thanks for the input.
Is it freshwater cooled or raw water? The oil is possibly just condensation from a low temp thermostat, or stat stuck open.
Pressure test the cooling system in the block, should be able to tell if it's cracked internally.
87 930, Last edited by 908/930; 07-23-2020 at 01:44 PM.. |
I know almost as much about boats as I do about spacecraft orbital math or the mating habits of bigfoot.
It would seem like a great excuse and a good time to upgrade to a newer engine. Maybe time for some Tim Taylor "more power!" grunting.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Maybe a Mercruiser 4.3 V6 swap ? You would be getting some more power , there are tons of them out there and it wouldn't over power your outdrive .
Unregistered
First question: is it leaking or was it leaking when in service?
Second question: is it a fresh water cooling system or closed loop (pressurized) cooling system? Thoughts: if it's fresh water and not closed loop, it is not a pressurized system. That plug will likely never see 1 psi and doesn't really need freeze plugs anywho. If it's a non-pressurized system and not leaking now, it probably never will. IOW is it really a problem? If it's a closed loop pressurized cooling system or shows signs of measurable leaking in the past, then yes it probably should be fixed. Brazing or welding with niresist rod (nickel) requires significant pre and post-weld heating. It would also be a good idea to bake the block to clean the pores to get good adhesion. Note that welding with nickel niresist is a mechanical bond like brazing, and NOT a molecular bond. it would not be as strong as new. Point is, you might need to line bore and hone the block after welding if it warps or moves, and that makes it not worth it unless it's really rare of expensive or special. At very least you are looking at complete dissasembly to do it right. metal stitching is pure friggin magic, if you can find a true metal-stitch artist you will be blown away. Incredible what they can do but it's a dying art. Not cheep for good ones either. About $200/hr is what I've paid in the past. If it's not leaking and not going to leak, consider it problem fixed. If it's leaked before or will leak enough to be a problem, then personally I'd look at replacement. https://www.boatpartsdepot2019.info/w-pick/165-hp.html 165 hp Mercruiser 6 cyl GM 250 CI good used engine block: $285.99 I'd make em an offer for $200 and see if they bite. They also have a complete engine for sale (used) for $1750 Seems high to me but what do I know? If if you're rich: $2,399.00 plus shipping for complete remanufactured engine with warranty https://www.michiganmotorz.com/inline-base-marine-engine-1963-p-546.html Prolly lots more and better deals out there, I only looked for a couple minutes. |
Unregistered
More info for the block above, it;s on e-bay:
Unregistered
Home of the Whopper
Dang Sammy, only things left for you to do is pick up the engine on your way here to install it!
Unregistered
I'd offer him $100 to haul it away. |
