Originally Posted by McLovin View Post
Good lord, that’s complicated!
I tried to do what you all said and I ended up crashing the Pelican BB for 2 days!
not hard at all
get one of these
https://www.amazon.com/Linksys-5-Port-Gigabit-Ethernet-SE3005/dp/B00FHREBDI
plug the modem port, the router wan port, and your NVR into this switch. enjoy it working. yes, it's that simple.
Old 10-23-2020, 08:30 PM
Originally Posted by Lexus4321 View Post
not hard at all
get one of these
That's ONLY going to work if he can get more than 1 IP which I'm not thinking is likely. And rather than buying another device, he could just plug the modem into one of the LAN ports of his current router and not use the WAN port and get basically the same thing. That would put all of the LAN ports on the same network and even the wifi stuff. The only difference would be that he'd need to disable the DHCP on the LAN side of the router.
Old 10-23-2020, 08:37 PM
Originally Posted by mclovin View Post
good lord, that’s complicated!
I tried to do what you all said and i ended up crashing the pelican bb for 2 days!
roflmao!!
Old 10-23-2020, 08:38 PM
Won't take long to figure that out, call the ISP. Most using docsis modems will give 10 devices (10 pub IP's).
Old 10-23-2020, 09:00 PM
