Grip It & Rip It
edgemar's Avatar
Engine Destruction
I can't believe the amount of destruction when one of these M97 engines lets go.
Wow!
82 911SC (sold)
Old 12-15-2020, 02:22 PM
Hell Belcho
Nostril Cheese's Avatar
That's called upselling....
Old 12-16-2020, 01:38 AM
Engine Destruction
Old 12-16-2020, 02:25 AM
How many times did that guy end a sentence with "OK?"
That crusher is amazing!
Old 12-16-2020, 02:42 AM
Bland
unclebilly's Avatar
‘Impossible to do this on the street without killing your self or going to jail...’
30% too much dork for me.
Old 12-16-2020, 05:07 AM
Bland
unclebilly's Avatar
Short shift kit leads to an exploded engine... umm hmm.
Old 12-16-2020, 05:08 AM
Senior Member
Superman's Avatar
At 6000 rpm, engines turn 100 revolutions per second. Let that sink in. When they let go, carnage ensues. Doug Zielke collected, as a hobby, photos of such Mechanical Mayhem. I would like to see those pics.
Mocha 1978 911SC. "Coco"
Old 12-16-2020, 09:18 AM
fastfredracing's Avatar
Yes, pretty much any engine that comes apart at redline , there will be mass carnage .
I once dropped a 10 mm nut down the cylinder of a 5.4 triton, and in less than 1 minute run time, I punched a hole in the block, destroyed the head, valves, piston, rod, and crank .
That one stung .
No left turn un stoned
Old 12-16-2020, 10:17 AM
Still Doin Time
asphaltgambler's Avatar
How about sooooo much boost it blows the entire block up off of the rotating assy?
https://www.youtube.com/watch?v=v-fa2g0T65s
Old 12-16-2020, 11:29 AM
Driver
Noah930's Avatar
That one stung .
If it makes you feel any better, YOU didn't punch a hole in the block or destroy the head/valves/piston/rod/crank. The 10 mm nut did.
1990 Black 964 C2 Targa
Old 12-16-2020, 12:04 PM
faverymi's Avatar
JB weld.
Hand file
Drive it
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 12-16-2020, 12:21 PM
Jeff Alton's Avatar
Very similar to any engine that either looses a rod bearing, or stretches a connecting rod bolt. I have a 997S engine in the shop that suffered a similar failure, but it does not look any different from a 2.0T VW motor that got over revved and lost two rods, punching large holes in the block and melting a couple of pistons..... Found part of a piston and wrist pin on the under tray. "OK"
It is not unique at all to a Porsche M96/97 engine... But does create great drama....
www.turn3autosport.com
Old 12-16-2020, 06:55 PM
The manufacturers test and then declare a REDLINE that is not to be exceeded. If one missed a shift and goes from 4th to 1st AKA the money shift it is the driver's fault, not the engine designers and makers.
Old 12-17-2020, 05:18 AM
Good head bolts!
Brent
Old 12-17-2020, 09:09 AM
That guy is the king of gloom and doom.
At least he is humble.
Old 12-17-2020, 11:56 AM
Grip It & Rip It
edgemar's Avatar
It's almost as if destruction is inevitable especially if you track your car...
82 911SC (sold)
Old 12-17-2020, 01:58 PM
Hell Belcho
Adventures with adjustable boost controllers. Ah those misspent teenage years...
Old 12-17-2020, 02:12 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Well there's yer problem.https://i3.kym-cdn.com/photos/images/masonry/000/621/998/a8f.png
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 12-17-2020, 02:38 PM
John Rogers's Avatar
There was a young fellow a few years ago in San Diego that had a 4L twin turbo engine put in his Turbo by Black Forest and it went to beat all! BUT it wasn't fast enough for him so his buddy and him decided to play with the electronic boost control and got it set to go up to 8 BAR which he tried on the newly opened state route 52. It blew the engine so badly the block had thousands of cracks in it and actually stretched the head bolts so much there was a large gap between the bottom of the cylinder barrels and the block and the crank was flopping around as there was massive clearance in the main journals! He went back to stock after that.
Old 12-17-2020, 04:51 PM
Gon fix it with me hammer
svandamme's Avatar
he literally uses the word literally way to much
Stijn Vandamme
BIMDIESELBMW116D2019
Old 12-18-2020, 01:31 AM
