fastfredracing's Avatar
Do you think a in fuel tank short, could cause an explosion, or fire ?
I ponder this every time I do an in tank fuel pump . Yesterday, I pulled one out of a 2009 cobalt, where there must have been high resistance right at the fuel pump connector on the pump submerged in fuel .
It got hot enough to melt the plastic connector, and turn the metal spades, purple .
Even though it is submerged, I am sure that under certain conditions, fuel would slosh and expose this to oxygen .
Is it possible ? I have never heard of it happening, and this is the only time I have ever seen anything like it .
No left turn un stoned
Old 02-16-2021, 11:59 AM
Did you get the memo?
onewhippedpuppy's Avatar
Just because it is hot doesn’t mean it would create a spark. Just being hot won’t ignite anything.
‘07 Mazda RX8
Old 02-16-2021, 12:13 PM
recycled sixtie's Avatar
So is it safe to do the work in immersed fuel?
Old 02-16-2021, 12:16 PM
I see you
flatbutt's Avatar
If the pump is immersed then there's no O2 to combust with...right?
So keep the pump submerged and no problem...maybe?
I rode my R1100S 14 years with that setup right in front of my gentleman bits.
Old 02-16-2021, 12:27 PM
Still Doin Time
asphaltgambler's Avatar
Not in that case, as said above oxygen has to be present + liquid doesn't ignite, the fumes do w/oxygen.
Old 02-16-2021, 12:43 PM
varmint's Avatar
Twa 800
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 02-16-2021, 12:54 PM
Uncounted millions of cars have the fuel pump inside the gas tank for a reason.
Old 02-16-2021, 12:57 PM
wdfifteen's Avatar
I never understood the reason for that. Cooling?
Old 02-16-2021, 05:42 PM
Slackerous Maximus
HardDrive's Avatar
Originally Posted by varmint View Post
Twa 800
I never bought the official explanation.
2014 Cayman S, PDK
Old 02-16-2021, 05:58 PM
In the tank the mixture is too rich to burn.
Old 02-16-2021, 06:05 PM
The fuel tank operates above the upper explosive limit ... insufficient oxygen for combustion / explosion
Old 02-16-2021, 06:11 PM
Senior Member
Superman's Avatar
All electric fuel pumps for gasoline are gasoline-cooled.
There is no O2 in liquid fuel. I'd guess there is very little O2 in the fuel tank at all.
Mocha 1978 911SC. "Coco"
Old 02-16-2021, 06:35 PM
greglepore's Avatar
Twa 800
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 02-16-2021, 07:08 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Spark erosion machines work in paraffin
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 02-17-2021, 01:06 AM
LWJ LWJ is online now
Interesting. Never thought of this.
Upper limit. Cool.
Old 02-17-2021, 04:45 AM
Lots of snow Porsche away
I've removed some of those capstain wire systems, and worked on the interting systems. The wires definitely represent a safety hazard when in vapor rich areas, the wire cases literally fell apart in that environment.
Old 02-17-2021, 08:19 PM
Bill Douglas's Avatar
Not inside the fuel tank, but when I was replacing the fuel pump under the car (lucky me - not) I got the perfect air to fuel ratio, and got a big orange flame/combustion.
It burnt the hair off one side of my head and left a sore on the side of my nose and above one eye. i had a fire extinguisher on hand so I saved the car then me in that order LOL
I was trying to get the fuel pump working when it sprang into life with a spark on the terminal and shot fuel out that was ignited by the big orange flame.
Old 02-17-2021, 08:49 PM
You do not have permissi
john70t's Avatar
I've heard they weld NG pipelines with the gas on.
Old 02-17-2021, 08:50 PM
beepbeep's Avatar
Fun fact: E85 in the winter might push the tank vapours under upper explosion limit.
Thank you for your time,
Old 02-18-2021, 12:44 AM
I see you
flatbutt's Avatar
I knew a man who was a welder for our local gas company and yes they do. If a leak opened up in a buried line he'd gear up, go down into the hole and weld it shut. Since it was absent O2 he could weld it. So he said.
Old 02-18-2021, 05:59 AM
