Why do they make can lighting fixtures 6 1/4 inch and hole saws 6 inch
Uggg. The largest hole saw I could find was 6" diameter but the can lighting fixtures that I am using are 6 1/4". I figured it would be no big but when I started cutting into my 1" thick plaster ceilings, the hole came out perfect and then when I used a file to ream out the hole to the proper size, the cuts are now all jagged and in a couple of cases, it chipped the plaster enough that I am going to have to fill.
Is there and easier way? I'm asking before I do the remaining 8 holes to cut.
GEt an adjustable hold saw for cutting out lights. It comes with a cover to catch all the debris. No more dust in your eyes, hair and clean is minimal.
https://www.homedepot.com/p/Klein-Tools-Quick-Cutter-Adjustable-Hole-Saw-53731/203828012?source=shoppingads&locale=en-US&mtc=Shopping-B-F_D27E-G-D27E-27_11_TOOLS_And_ACCESSORIES-NA-NA-Feed-LIA-NA-NA-TOOLS_ACCESSORIES&cm_mmc=Shopping-B-F_D27E-G-D27E-27_11_TOOLS_And_ACCESSORIES-NA-NA-Feed-LIA-NA-NA-TOOLS_ACCESSORIES-71700000052584485-58700005051480447-92700050457564051&gclid=Cj0KCQjwutaCBhDfARIsAJHWnHvWfDlCn8Cg89DONeQH 517mbgkY3TQrs42Rs294vw_xQLkRR0msUNoaAizxEALw_wcB&gclsrc=aw.ds
This will do the trick for one time use but the blades dull out quickly cutting through plaster. We have ones that have a carbide tip interchangeable blades, but those are close to 100 bucks. |
The Unsettler
Why do they sell hotdogs in 6 packs but buns in 8 packs?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Still here
![]() Why do you need a 17/32 socket ? |
So you'll buy 24 of each?
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
dolor et pavor Copyright |
