Originally Posted by TimT View Post
I have a key for those wheel locks that looks like it might fit..
Looks like a perfect fit.
There ya go, Gambler....problem solved!
And Tim gets a case of beer!
Old 08-08-2022, 09:22 AM
Control Group
Tobra's Avatar
Moral of the story, wheel locks are the devil
Old 08-08-2022, 10:36 AM
Counterclockwise?
Can you cut the studs off from the other side?
Rod
1986 Carrera
2001 996TT
Old 08-08-2022, 11:01 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Gotta remove the wheel to get to the back of the stud then its an acrobatic exercise with various die grinding wheels.
1981 911SC Targa
Old 08-08-2022, 12:03 PM
Still Doin Time
asphaltgambler's Avatar
I had these locks on a car years ago, and removed them and tossed them in a toolbox drawer...
LMK if you want to try
Tim - sent you a PM
Old 08-08-2022, 02:38 PM
The Unsettler
stomachmonkey's Avatar
Damn looks like an exact match.
Even if one or two of the pins are off you could probably just grind them off.
Do we really think it needs all 5 pins to do the job?
"I want my two dollars"
"Brandon Won"
Old 08-08-2022, 03:21 PM
fred cook's Avatar
Thinking inside the box.........
Why not drill out the stud inside the lock? It might take several bits but at least your nice $$$ wheels would be protected. Once you get the wheel off, just replace the wheel stud. If you can't get it with drill bits, try a grinding bit in a high speed air tool. Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-08-2022, 03:48 PM
Yeah....that's why I brought the images together in one post.
They are an exact match as far as I can see.
Like I said - problem solved. Close the Internet for the rest of the day...
Old 08-08-2022, 03:51 PM
Mahler9th's Avatar
That product was I think sold by Automotion and/or Garretson's back in the day. I used to have a few sets. When one of my keys broke, I discovered that the company was right off of Old Middlefield in Mountain View, right near the location of the Garretson/Barbour racing team that spawned the creation of, for example Automotion.
Those pins can break off so I advise caution.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 08-08-2022, 05:44 PM
Jeff Hail's Avatar
Looks like the dreaded Ralph Booth wheel locks. Everyone here has some good ideas.
The pilot holes are the key code to remove the forcing cones. Think backwards !
22 MM Gorilla Grip should be the correct size. Get some bolts that will fit the pilot holes or cut some heads off some socket caps and make 3 or 4 fingers. Insert into the pilot holes and then press the Gorilla Grip over the bolt shanks. Dont need to be long. 1/2 or 3/4 inch length length should work. Just keep pressure towards the wheel. Might take a few tries to get coordinated with a budy.
Your key looked like this.
You need to make something like this.
With McGiver stuff like this. This is a 19mm Gorilla Grip. I would find a 22mm. Short stubby bolts that make the pins. Make sure the need pins in the socket are not shuffling around and that cone will come off.
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 08-08-2022, 08:03 PM
Still Doin Time
Thanks all - So Tim is kind enough to lend me his key, as already stated by stomachmonkey that - not sure if I need all the pins. I think 4 would be enough as the torque is @95ft lbs.
I think the pattern looks very close though. If not, the base nut is aluminum and fairly soft as when I tried to clock it loose with a long punch into one of the holes, the metal was more pliable than even I would have thought.
So if the pattern is not close I'm confident that I can drill the base nut. So stand by all...............
Old 08-09-2022, 03:01 AM
Shaun @ Tru6's Avatar
if you end up having to drill new holes to match Tim's key, put some nail polish, Gucci's Goldie Red is good, on the ends of the pins and touch the lock. Dries fast, use a punch to mark, 1/16 drill bit to start and then 1/8 or whatever the pin diameter is. good luck!
The reverse works too: toothpicks or small machine screws in the holes on your lock, nail polish on ends, touch a 3/4 nut from Home Depot to mark, drill press holes in the nut and then you can either use drill bits as pins for a temp solution or machine screws to make a new tool.
Tru6 Restoration & Design
Old 08-09-2022, 04:35 AM
Still Doin Time
Yes, exactly what I’ll do, I have bright red touch-up paint have center-punch marking tool
Old 08-09-2022, 04:54 AM
Still Doin Time
So check this out. TimT sent me his lock key and threaded holder, received in the mail today. In the interim I installed the new tags, then wiped the glove box out, removed the owner's manual packet to clean. As I remove the booklets from the vinyl holder guess what was in there?
This is the wheel lock key card with the key code that of course was buried in the owners manual as I NOW recall doing. If you look closely see the hand written code =8C
I open the box containing the wheel lock that TimT sent me - look at the engraved code on the face...........guess what it says?
....8C!
So what are the odds of all the key code combinations, from a company that apparantly is no longer in business, and a fellow Pelicanite just happens to have a spare set willing to lend you their key and holder?
All-in-all a pretty awesome day if you ask me!
Old 08-13-2022, 03:58 PM
Told you it was a match!
But to your greater point - absolutely fantastic that it worked out so well.
Much respect to Tim!
Now go get yourself some lottery tickets, Gambler!
Old 08-13-2022, 04:08 PM
Model Citizen
herr_oberst's Avatar
The Pelican Universe abides.
Still Doin Time
God's Blessing on me today as this restoration has been so difficult and time consuming I'm convinced the car hates me. But not today
Old 08-13-2022, 04:27 PM
pwd72s's Avatar
Boy howdy on that!
Old 08-13-2022, 04:31 PM
That's outstanding!
Old 08-13-2022, 05:10 PM
WPOZZZ's Avatar
That means AG or TimT's next car will be an 8C!
Old 08-13-2022, 05:54 PM
