Looks like a perfect fit.
![]() There ya go, Gambler....problem solved! And Tim gets a case of beer!
Old dog....new tricks..... |
Control Group
Moral of the story, wheel locks are the devil
She was the kindest person I ever met |
Counterclockwise?
Can you cut the studs off from the other side?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Fleabit peanut monkey
Gotta remove the wheel to get to the back of the stud then its an acrobatic exercise with various die grinding wheels.
1981 911SC Targa |
Still Doin Time
Tim - sent you a PM
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
The Unsettler
Even if one or two of the pins are off you could probably just grind them off. Do we really think it needs all 5 pins to do the job?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Thinking inside the box.........
Why not drill out the stud inside the lock? It might take several bits but at least your nice $$$ wheels would be protected. Once you get the wheel off, just replace the wheel stud. If you can't get it with drill bits, try a grinding bit in a high speed air tool. Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Yeah....that's why I brought the images together in one post. They are an exact match as far as I can see. Like I said - problem solved. Close the Internet for the rest of the day...
That product was I think sold by Automotion and/or Garretson's back in the day. I used to have a few sets. When one of my keys broke, I discovered that the company was right off of Old Middlefield in Mountain View, right near the location of the Garretson/Barbour racing team that spawned the creation of, for example Automotion.
Those pins can break off so I advise caution.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
Looks like the dreaded Ralph Booth wheel locks. Everyone here has some good ideas.
The pilot holes are the key code to remove the forcing cones. Think backwards ! 22 MM Gorilla Grip should be the correct size. Get some bolts that will fit the pilot holes or cut some heads off some socket caps and make 3 or 4 fingers. Insert into the pilot holes and then press the Gorilla Grip over the bolt shanks. Dont need to be long. 1/2 or 3/4 inch length length should work. Just keep pressure towards the wheel. Might take a few tries to get coordinated with a budy. Your key looked like this. ![]() You need to make something like this. ![]() With McGiver stuff like this. This is a 19mm Gorilla Grip. I would find a 22mm. Short stubby bolts that make the pins. Make sure the need pins in the socket are not shuffling around and that cone will come off.
Jeff Hail "All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible" |
Still Doin Time
Thanks all - So Tim is kind enough to lend me his key, as already stated by stomachmonkey that - not sure if I need all the pins. I think 4 would be enough as the torque is @95ft lbs.
I think the pattern looks very close though. If not, the base nut is aluminum and fairly soft as when I tried to clock it loose with a long punch into one of the holes, the metal was more pliable than even I would have thought. So if the pattern is not close I'm confident that I can drill the base nut. So stand by all...............
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold Last edited by asphaltgambler; 08-09-2022 at 03:03 AM.. |
if you end up having to drill new holes to match Tim's key, put some nail polish, Gucci's Goldie Red is good, on the ends of the pins and touch the lock. Dries fast, use a punch to mark, 1/16 drill bit to start and then 1/8 or whatever the pin diameter is. good luck!
The reverse works too: toothpicks or small machine screws in the holes on your lock, nail polish on ends, touch a 3/4 nut from Home Depot to mark, drill press holes in the nut and then you can either use drill bits as pins for a temp solution or machine screws to make a new tool.
Tru6 Restoration & Design |
Still Doin Time
Yes, exactly what I’ll do, I have bright red touch-up paint have center-punch marking tool
Still Doin Time
So check this out. TimT sent me his lock key and threaded holder, received in the mail today. In the interim I installed the new tags, then wiped the glove box out, removed the owner's manual packet to clean. As I remove the booklets from the vinyl holder guess what was in there?
![]() This is the wheel lock key card with the key code that of course was buried in the owners manual as I NOW recall doing. If you look closely see the hand written code =8C I open the box containing the wheel lock that TimT sent me - look at the engraved code on the face...........guess what it says? ![]() ....8C! So what are the odds of all the key code combinations, from a company that apparantly is no longer in business, and a fellow Pelicanite just happens to have a spare set willing to lend you their key and holder? All-in-all a pretty awesome day if you ask me!
Told you it was a match!
![]() But to your greater point - absolutely fantastic that it worked out so well. Much respect to Tim! Now go get yourself some lottery tickets, Gambler!
Model Citizen
The Pelican Universe abides.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Still Doin Time
God's Blessing on me today as this restoration has been so difficult and time consuming I'm convinced the car hates me. But not today
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
That's outstanding!
That means AG or TimT's next car will be an 8C!
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
