Air Medal or two
Fix crack in helicopter Bubble ?
Turns out to be more of a language and more linguistics than ever intended.
I will just find a new or used bubble.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. Last edited by afterburn 549; 05-19-2024 at 03:57 PM.. |
PM me some pics.
1996 FJ80. |
What material is it? If it is acrylic look at products from Weld-on. Need good ventilation. Weld on 16 is a pretty good filler that I have used in the past.. Weld on 40 or 42 are two part filler but I have never used.
87 930, |
Weldon is the word.
My other ride is a C-130J
What make and model of whirley bird is it ?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Thanks for the info.
I hope the term “whirley bird” isn’t an inappropriate term for a helicopter pilot. I’m a fixed wing guy.
Air Medal or two
Hiller Raven OH 12 C (UH23C) (OH23)-All the same Bubble
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Air Medal or two
There was a show on TV called The Whirly Birds Late 50s So I guess it is appropriate.
Edministrator
What did you fly in the Air Cavalry?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Weld-on #4 is just a solvent, good for overlap bonds, I do not think it is what you want to use. The #16 is thicker it has some filler material in it, same solvent base.
87 930, |
I don't think you will need to drill if you can bond it properly, was the stress that caused the crack internal? With the #4 it will flow through just about any space like water but you need to be able to force it together to get the material to bond. How long is the crack and how thick is the material?
87 930, |
For AB:
![]() I know a lot of Helo Depot folks and they may have some suggestions. I'll need pictures and what it is made of and age since I have no idea how to repair - hopefully they may be able to help.
1996 FJ80. Last edited by Seahawk; 05-18-2024 at 05:37 AM.. |
Air Medal or two
Will be pix here in about an hour
Thanx for the Baby Huey pic, LOL In the early morning mist a roll with the wrist A push on the button Things came into motion we started to lift In the early morning mist the sun not quite up Headed for another LZ another insertion or pickup It was always all the same dodging the green tracers the pounding of the blades in the mist blood and rain Now to wash it all the red stains
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. Last edited by afterburn 549; 05-19-2024 at 04:00 PM.. |
Yikes, those look like big cracks that need to be fixed. Seems like replacement would be ideal except to your wallet.
Air Medal or two
I would replace it, if I could find the parts.
What year is your helicopter? I know it is a Hiller Raven, but what year and when was the last time it flew?
The initial response from the folks I know that do this was not positive. If you are flying a certified aircraft, the manufacturer is the deciding authority on, trust me on this, cracks in canopy bubbles and doors and the required fixes to maintain that certification. An AP will insist on that before signing off on the repair. Any fix must have a basis in the certification. I really want to help you with this. So, what manuals do you have from Hiller? That was their first question. Let's start here: https://hilleraircraftcorporation.com/all-model-revisions-publication-status Or here: https://www.aircraft-reports.com/hiller-hte-h-23-oh-23-raven-helicopter-manuals-bundle-on-dvd-or-download/ https://www.eflightmanuals.com/ITEM_EFM/SDETAIL_EFM.asp?mID=1151 If you don't want my help, I understand. Remember I have a lot of hours and factory time in helos...you may need help getting an airworthiness certificate. I could be wrong. Let me know.
1996 FJ80. |
Do you happen to own a vacuum pump? Do you have a place to purchase a small piece of acrylic to practice on, any sign shops nearby?
What Seahawk said could change things.
87 930, Last edited by 908/930; 05-18-2024 at 10:29 AM.. |
I would call them:
https://hilleraircraftcorporation.com/what-we-do Hiller Aircraft Corporation 925 ‘M’ St Firebaugh CA, 93622 Info@hilleraircraft.com (559) 659-5959 Again, I know how hard this is...we stopped doing FAA repairs because, and I do not disagree at all with their standards, keeping our quals for the FAA were onerous.
1996 FJ80. Last edited by Seahawk; 05-18-2024 at 10:45 AM.. |
When one is repairing an aircraft before the existence of the FAA… The thought of regulation overreach comes to mind…
There’s a lot of static displays around, maybe reach out for a trade on a non cracked bubble.
dolor et pavor Copyright |
