Dealing with a stump without having it ground out.
Last year, I had a tree taken down and asked them to cut it as close to the ground as possible. It was close to the fence line on the edge of a field, so I thought I would just drive over it with my JD. They left it about 6 inches high and impossible to drive over.
I decided to use Stump-Out.
The stump measured 6' 7" in circumference. I had some 10" flashing that I cut to 7' long and made a small barrel around it. I used my Bauer 10" battery chain saw to score the top in multiple lines. Poured the Stump-Out in, added water, and let it set for 6 weeks.
Last Wed., I added a couple layers of Kingsford to the top and 'lit er up'.
It burned for 3 days and then rain came.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 01:10 PM
6 bags of topsoil added
Grass seed and straw added and watered.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 01:15 PM
Nice!
Good thinking on using the fire to burn it out after you killed it.
Old 07-18-2025, 01:30 PM
A930Rocket's Avatar
Nice work!
Don’t be surprised, if you need to add additional dirt, as the stump decays.
Old 07-18-2025, 01:39 PM
^^^ If it hadn't rained...I'm sure it would smoking and smoldering yet.
But I didn't need that...it did it's job.
The fire left the outer bark...I think the heat couldn't get to it good. So I used my Bauer to cut that off...which went easy.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 01:40 PM
Nice work!
Yeah, I am kinda counting on that. At least I can mow over that area again. (after the grass seed takes off)
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 01:42 PM
If you go the same route with the 'Stump-Out'....be aware that you might need two of them.
The one pound can doesn't go far.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 02:51 PM
Still here
pmax's Avatar
Old 07-18-2025, 03:20 PM
LWJ LWJ is online now
Brilliant solution. I have a bunch of stumps at the family farm. Too bad I can't buy dynamite anymore...
Old 07-18-2025, 03:25 PM
^^^ Pmax
My place is on a hill and there are three lakes within a half mile and one is a mile long.
Not much worry of fire here.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 03:32 PM
I know...I remember going with my G'pa to buy sticks when I was a kid. Buy them at the hardware in town...and then go to a shed in an isolated area to get the dyno.
It was an easy way to clear a field.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-18-2025, 03:35 PM
wdfifteen's Avatar
Excellent! Nice job.
Old 07-18-2025, 05:49 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
I had a big tree removed from my yard recently. The removal service did the same thing only they drilled about a dozen holes deep into the stump and soaked it in diesel fuel for a couple days before adding the coals and lighting it.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-18-2025, 08:04 PM
One could even clear out gullies, etc. for farm ponds too .... turtle ponds ... sliders and big ol' snappers appreciate it too!
Nice job ... reminds me of Great Grandpaw Stumpy and country engine-ears
Old 07-19-2025, 03:53 AM
I tried that with my 20V battery drill...it got very hot before I could even do one hole.
The stump was about 200 feet from an outlet, so my corded drill was out.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Anything that saves me from trimming around it is worth it.
I use pramitol around each fence post, but to do that around the stump would make a large dead area.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-19-2025, 03:58 AM
Yer either lazee or smart ....
Or both !
Old 07-19-2025, 04:05 AM
rfuerst911sc's Avatar
Another option although slower is use Epsom salt . Drill some holes in top of stump . Pour the salt in the holes and on top of the stump . Cover with a pile of leaves . This method speeds up the natural decay/rot .
Old 07-19-2025, 04:34 AM
unsafe at any speed
wswartzwel's Avatar
Thanks for sharing this. I have some stumps on my property that need removed so I can mow. I will give this a try.
Bill Swartzwelder
Old 07-19-2025, 04:36 AM
Before I used the stump out, I tried my sharpened axe to see if I could chip off enough of the outside top of the stump to give a gradual rise for the mower.
I don't do it often, but I know how to swing an axe. That dried surface of a few years dead elm is like concrete. If the axe doesn't hit it square...it just ricochets off. I gave up with that after a dozen swings.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-19-2025, 04:46 AM
