Need a battery gas transfer pump...
One that will work (best) on draining a Carrera fuel tank... i.e. flexible hose.
I have a manual pump, but want one and will also use it for other gas transfers from a can to mowers, etc. Thanks! |
I just disconnected the fuel pump hose and use free gravity to drain my tank when I replaced the tunnel gas lines. I gathered all my fuel tanks used for lawn equipment, and filled them all. When I started running out room in those, I poured the gas into my El Camino tank.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Brew Master
Just pull the tank drain in the bottom... whoosh! out it all goes. Word of warning! Wear clothing you don't mind throwing away when you're done. And have a large enough container to catch was comes blasting out. Come to think of it, maybe the battery pump is a better way to go.
Nick Last edited by cabmandone; 09-03-2025 at 07:10 AM.. |
Manual pump seems like a good option.
Electric pump seems like a sketchy option unless it's high quality. No sparky Chinese stuff pumping gasoline or jet fuel for me. I feel like we had a thread a while back about gas cans for filling mowers and such that contained talk about pumps so you didn't have to manhandle the 5 gallon cans. I think I remember Turtle-Steve talking about a pump maybe.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Turtle Steve, FTW!
I imagine you're the cousin of Pirate Steve.
Thanks guys! I'll get one for the 5 gal cans that feed my Scag. The 911 is on dollies
.... I either drain (what I think is just a few gals) via above or she gets a ride ... to a lift or something ![]() I'll use my dinky one ... might go get a gas line/bulb off a boat down at the marina if that doesn't work. Can a flexible tube get into the tank vial the filler ... or ??? There will be no "whooshing" .... I hope! |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
[QUOTE=masraum;12526400]Turtle Steve, FTW!
I imagine you're the cousin of Pirate Steve. No...but I kinda like his gold teeth. (not a fan of the Puffy Shirt)The more I think about it...the battery powered one that I use (from the above link) probably wouldn't work. The intake end is rigid plastic...would not go thru the gas intake of the car. But it sure works nice for filling my JD....I never lift a 6 gal jug anymore to fill it.
Hey KC,
Recently went through this and used the linked unit from Hobo Freight - just pull the fuel sending unit on top of the tank and drain. Easy peasy. https://www.harborfreight.com/battery-operated-liquid-transfer-pump-63847.html
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
^^^ Awesome.... thank you
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Tons available from online sellers. I've even bought them from my local Walmart.
I use them for my motorcycles mostly but also for gas cans, etc. Here I'm moving Evapo-Rust from a 5 gal. pail to individual gallon containers for ease of usage.
Old dog....new tricks..... |
+ lurking - contributing
Baz has the right pump, available at Harbor Freight. Extremely convenient, I have used it to drain my 930 of stale gas after removing fuel level sender at top of tank. From the sender opening you can insert pump suction stem and drain 99.5% out into container of your choice. Get a new cork seal for the sender too.
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
^^^^^^ I have one and it works great.
Keep talking, Im gonna put you in the trunk. |
I’ve used a low psi 12v fuel pump with rubber hoses to clean out old fuel tanks. Some common sense and long leads to keep it safe.
dolor et pavor Copyright |
Brew Master
Nick |
Crap ... only pumped about 4 gals out ... prolly another 3-4 left. I can see rust above the "gas was here" line in the tank
. I'll get the rest out ... I need her in a different garage ... do I put a couple of fresh gals in (below the rust line) and drive, or is that a really bad idea
Fleabit peanut monkey
Do what Glen suggests (pull fuel pump hose) now that you are close and then put the fresh in.
Tank drain is more exciting, though.
1981 911SC Targa |
I can pump the rest out no problem Bob ... I need to empty this can or bring another empty one ... it's too nasty/old to pour in my F150
.This rust detection is ...Always sumthin'.... |
